Sponsored by: Real Truck
Replacement Steering stabilizers
Old Oct 10, 2006 | 06:05 PM
GKDave's Avatar
GKDave
Hi folks,
First, I'd like to thank everyone for all the responses on which shock to buy for my F350 SD 4x4. Looks like Bilstein is the brand. I also want to replace the stock steering stabilizer with an aftermarket replacement. Other than the Rancho, does any other company have a replacement stabilizer for the stock OEM location and mounts?
Thanks,
Dave
Old Oct 10, 2006 | 06:38 PM
EnviroCon's Avatar
EnviroCon
Fabtech, Rough Country and Skyjacker come to mind. But their performance is probably going to be about the same as Rancho's. If you go with a dual-stabilizer set-up than Superlift and Donahoe racing have Bilstein (they call them Signature Series) shocks that go with them.
Old Oct 10, 2006 | 07:50 PM
bneafus's Avatar
bneafus
Put a Rancho on my rig with the lift kit and new shocks. Seems much better. Haven't had the death wobble..
Old Oct 10, 2006 | 08:11 PM
ReAX's Avatar
ReAX
I have flipped through bilstiens catalog, but I couldn't find much in the line of steering dampners. They had some VW's, but nothing that looked like a bolton.
Old Oct 10, 2006 | 08:45 PM
EnviroCon's Avatar
EnviroCon
As far as I know, Bilsteins only come on the aftermarket applications. A Bilstein might work in the stock location, I've never actually tried. But here a couple of pics that show the size difference between the 2 shocks.
The steering is straight forward on my truck and you can see just how tiny the stocker is compared to the Bilstein.
Old Oct 10, 2006 | 08:48 PM
ReAX's Avatar
ReAX
Do you have a part # for that one? The silver style is what I was in the book for.
Old Oct 10, 2006 | 09:17 PM
EnviroCon's Avatar
EnviroCon
Here's what's stamped into the shock body: 1604BE5 6253XX. But it looks like the "XX" was stamped over what looks like "N5", but I'm not positive of that.
The shock body was the only place I could find a number. I can't seem to find the Bilstein P/N anywhere else, like the instruction sheet from Donahoe. I checked Donahoe Racing, Superlift, and several of their distributors sites and no one lists the Bilstein P/N. If you wanted to, I imagine you could PM DC Special or call Truck Toyz directly and they'd be able to get the P/N, or tell if you, if it would fit in the stock location.
Old Oct 10, 2006 | 09:30 PM
ReAX's Avatar
ReAX
BE5-6253 is a regular part number. I am checking it now.
Old Oct 10, 2006 | 09:33 PM
Rollin03F250's Avatar
Rollin03F250
Is that just an add on, to the stocker? Why not jus get 2 of the same?
Old Oct 10, 2006 | 09:34 PM
ReAX's Avatar
ReAX
LIFT TRK 218.5MM STK 8.60"ZINC
Manufacturer: BILSTEIN
New part#: F4-BE5-6253-H5
List Price: $ 136.00
Category: Shock Absorbers
I found it, BE56253H5 jobbers at 81.63.
I'll try to pull the specs tomorrow at work and see how they line up.
Old Oct 10, 2006 | 09:47 PM
ReAX's Avatar
ReAX
BE5-6253-H5 8.5" 5125 Series 8.6" 14.06 22.5 EB1*/EB1 1/2" Yes plated
The application list calls for 78-79 Bronco. My 79 F150 had an eye lower and stud upper, so the * must mean the upper mount is a threaded on eye.
Old Oct 10, 2006 | 09:59 PM
ReAX's Avatar
ReAX
An RS5410 Bolts to stock.
RS 5410 list as follows:
RS5410 L1 LS38 14.500" compressed 24.375" extended 9.875" travel
L1 is a bushing only mount, LS38 is a bushing with sleve mount, both appear to be eyes.
The bilstien is 8.6" travel, 14.06" compressed and 22.5" extended. So it is nearly 2" shorter and has 1.275 less travel. That must be why it's not a bolton.
Old Oct 10, 2006 | 10:19 PM
EnviroCon's Avatar
EnviroCon
I went out and dug-up the stocker for my '04 and measured it from center of eye to center of eye.
Fully compressed= 15"
Fully extended= a hair over 23"
So about 8" of travel. Unfortunately, I have no idea how much travel actually occurs with full wheel lock in either direction. I assume no more than 4" with a stocker on there.
Old Oct 10, 2006 | 10:22 PM
ReAX's Avatar
ReAX
Usually the piston will be shinier on the part that actually goes into the tube. So add the shinny to the compressed lenght and that should give you the room it needs and the rest is just gravy.
From what you have measured it will work.
Old Oct 10, 2006 | 10:39 PM
EnviroCon's Avatar
EnviroCon
Normally yes, that would be a good way to tell. But my truck went straight from the dealer to the local tire shop to have the stock tires removed and BFG MT's put on. Then it took about another 4 days for Superduty Headquarters to get me the lift and dual stabilizers, so the stock stabilizer's pretty much brand new and has just been sitting compressed in the "removed parts" box ever since.
