Sponsored by: Real Truck
Snow Plowing this winter
Old Nov 6, 2008 | 03:00 PM
rwilimo's Avatar
rwilimo
I run the stock alternator on my 04 with no problems although I did add a second battery. I run a Western 8.5" strobes, and an led roof beacon.
Old Nov 6, 2008 | 03:20 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
Originally Posted by winged1dur
Jim, the ballast advice IS for handling purposes; traction is a secondary benefit. When plow customers are calling to see where you are (stuck in driveway #3 of a 25 driveway route) you won't be worrying about your drive train's "fuse"!
W1 - so you'd rather be dead in driveway #3 with an exploded u-joint than just stuck? I'll take stuck, thanks...
You mentioned 850 pounds - that's way past for ballast needed for handling - recommended ballast for the 8' HD plow on my 350 is around 350 pounds, IIRC. But I've never run ballast in any pickup I've plowed with. Yes I've been stuck a couple times, but I've never broken a single piece of drive line while plowing. Had to replace u-joints as maintenance, bit never 'cause they failed outright.
Old Nov 6, 2008 | 04:18 PM
winged1dur's Avatar
winged1dur
Jim, lets start over. The guy started the thread asking for advice on HIS truck. Your truck is very different than his so comparisons are useless. I ran his truck in the Fisher plow ematch and the ballast recommendation is 970 lbs. His truck is much more front heavy than yours. Ballast will even this out.
For what it is worth I have never replaced a u-joint on either truck and have found through experience ballast works.
You are entitled to your opinion and so am I.
Old Nov 6, 2008 | 04:20 PM
ken kenmnedy's Avatar
ken kenmnedy
OK heres the scoop when you put that plow on a PSD 99-03 you need to ballest the rear because you will be nose heavy and tippy I sub contract to a guy thats got 2 PSDs he uses a 2yd salter in the back of his and he had a spring shop make him extra leaf for the front on each side every season he will need to change those front wheel bearings I have seen it the last three seasons ouch so when you aint plowin put that big thing down and unhook it from your truck
Old Nov 6, 2008 | 05:12 PM
pbeering's Avatar
pbeering
Surf to www.letstalksnow.com.
Your truck will do fine.
I'd suggest:
higher capacity springs
timbren helper springs up front
1000 lbs of ballast over the rear wheels
higher output alternator
Strobes are fine, so are LED's. Stay away from the rotator, and halogen warning devices because they drink electricty and that truck does not have a fully fielded alternator.
Lastly, you need Fluid Film for the plow and fittings.
Old Nov 6, 2008 | 07:35 PM
Eng1Driver's Avatar
Eng1Driver
Check your battery and if you have any doubts replace it. Plows and lights draw lots of juice and at 2am you won't be finding a replacement.
Old Nov 6, 2008 | 08:02 PM
DCSpecial's Avatar
DCSpecial
I always run ballast to keep enough weight on my rear tires to keep from fishtailing while turning on the roadways.
Old Nov 6, 2008 | 09:20 PM
NewEnglandHerdsman
Easy son...
Right you are on the fisher recommendation, I stand corrected. That particular setup does sound like it could use some, but a 1/2 ton of ballast? Wow, that's a lot. I've run 6 wheel dump trucks with about that much...
But, me personally? (Yes, my opinion.) I'd never put that much extra weight in a pickup truck just to plow. Plowing can be tough enough, that's just asking to break something...
And I do stand by my opinion that I'd rather be stuck then broke...
Old Nov 7, 2008 | 11:57 AM
sgthawkusmc's Avatar
sgthawkusmc
Personally I've never run ballast. I've heard the arguments both ways and it would probably be better, but I use the bed of my truck. I don't want to have to remove 1/2 ton of cement etc to put something back there after each storm. I can count the number of times I've gotten stuck on one hand and I've been plowing for quite a while.
Old Nov 7, 2008 | 12:43 PM
jonsk's Avatar
jonsk
i throw my 600 lb atv in the back when i have my plow on. I do need the bed so i dont want ballast in there all winter.
Old Nov 8, 2008 | 11:07 AM
DCSpecial's Avatar
DCSpecial
My ballast has always been bags of salt, that I spread once the storm is over
Gomer1
Jan 10, 2015 09:44 AM
Tom
Oct 29, 2011 12:22 PM
BigPigDaddy
May 6, 2010 11:13 PM
1977f150xlt
16
Oct 9, 2009 01:18 AM
gworks
Jan 20, 2008 12:35 PM
