cam swap thread
Old Dec 17, 2008 | 10:59 AM
  #91
paintslinga2010's Avatar
paintslinga2010
OK, I have almost everything back together. Hopfully ready to start tonight. How fast do i run the drill? Is there anything else i need to know before i try to start it?
Old Dec 17, 2008 | 11:32 AM
  #92
Conanski's Avatar
Conanski
Once you start to build oil pressure you'll feel the load on the drill, don't burn the thing up just run it where it feels comfortable for 30 sec or so. Good luck.
Old Dec 17, 2008 | 11:36 AM
  #93
Opossum's Avatar
Opossum
Unless you have a vary powerfull drill you won't be able to turn it too fast, just hold on.
Old Dec 19, 2008 | 09:52 AM
  #94
KDPate's Avatar
KDPate
I use a 3/8 Cordless drill (Makita 18V) and a 12" long 1/4" drive extenstion with a 5/16" deepwell socket (all ofthisis available at Sears) to get to the oil pump drive shaft. Be sure the drill is going counter-clockwise and hold on WITH BOTH HANDS!!!!! Should start to see oil coming out of the pushrods after about 15-20 seconds of running. Button everything back up and then it sould be ready to go...
Old Dec 19, 2008 | 11:19 AM
  #95
paintslinga2010
Im glad you said that KDPate. I assumed i was going to run the drill clockwise. I had a game last night so i didnt get the chance to try to start it. Hopefully tonight.
edit: just read where conanski said to run the drill counterclockwise also. I need to read more thoroughly.
also, i already have everything together so i wont be able to see the pushrods. Any other way to check or should i hope i put everything together right and go for it?
Old Dec 19, 2008 | 12:57 PM
  #96
Conanski's Avatar
Conanski
If you remove the oil fill cap and shine a light in there you should be able to see when oil reaches the top of the motor.
Old Dec 19, 2008 | 08:36 PM
  #97
paintslinga2010
dang...no start, motor turns over and pops out of the exhaust a little bit. Is the timing out? I thought i kept everything in check and and at tdc. I know it was a tdc because when i replaced the timing chain the marks were lined up. Whats the deal?
Old Dec 19, 2008 | 10:05 PM
  #98
Conanski's Avatar
Conanski
Try advancing the distributor.. push the TFI module right up against the thermostat housing to see if it makes any difference, if it does then you have the distributor off 1 tooth.
Old Dec 19, 2008 | 10:11 PM
  #99
Opossum's Avatar
Opossum
Sounds like the ignition timing is way off, probably 180 deg.
Old Dec 19, 2008 | 11:06 PM
  #100
paintslinga2010
Good news. My dad had a buddy of his who is a mechanic come over. The timing was off. We go it going and timed. But theres an antifreeze leak somewhere i cant track down. Im going to check all the hose clamps tommorow morning, then go from there.
When we had it going it sounded mean. In the morning Im going to try to get the antifreeze deal down and get it on the road to see how it does. Sure was a good feeling to hear it roar to life.
I want to thank all of you guys that helped me, and hopefully this thread can help someone in the future.
Any other things to watch out for when i start driving it?
Old Dec 20, 2008 | 02:36 AM
  #101
DJdemon6696's Avatar
DJdemon6696
gr8 to hear you got it running.. make a vid of it idling and ripping when its proper brake in
Old Dec 21, 2008 | 05:17 PM
  #102
paintslinga2010
I got to put it through its paces today. I was pretty impressed. It pulls hard way up in the rpms. Where as before it would just rev out it keeps going. Makes me realize I need to get the rear end turning both wheels. If i got to hard on the gas in 2nd the back right tire just spun.
Im going to need to do some more adjustments, the throttle is stiff now..i dont know why, must have messed something up during the swap.
Also I still have no heat! new thermostat and flushed heater core. wtf...
Old Dec 22, 2008 | 09:39 AM
  #103
KDPate's Avatar
KDPate
Air bubble maybe in the cooling system? Might want to leave the cap off or loose and let it run until anti-freeze comes pouring out. Had hell getting the ar bubble out after I replaced the t-stat and heater core on my truck (took about 3 or 4 attempts)....
Old Dec 22, 2008 | 11:26 AM
  #104
Conanski's Avatar
Conanski
Yep.. run it with the rad cap off until the thermostat opens and you can visibly see coolant circulating in the rad. It may also help if you park the truck with the front elevated a little.
Old Dec 22, 2008 | 09:21 PM
  #105
paintslinga2010
Added coolant, drove it for about a half hour total tonight. I cant get enough of it. So much power way up into the rpms, where it used to feel like it was gonna blow now feels likes its in the meat of the powerband. So far i have only got it to 4 grand. Sometime ill figure out where it stops, but not until i make sure everything is solid.
Still no heat unfortunatly. I didnt have alot of time to mess with it but i felt the heater core cover and its pretty warm, but the air blowing out is lukewarm.
