gauges install question...
Old Nov 5, 2008 | 07:52 PM
Wieckster's Avatar
Wieckster
I dont think my trans gauge is working it doesnt move is the a way to tell if its the gauge or the probe?
Old Nov 5, 2008 | 07:54 PM
Ponyboychris's Avatar
Ponyboychris
What was the ambient temp outside today and how long did you drive your truck?
Old Nov 5, 2008 | 11:01 PM
willeo6709's Avatar
willeo6709
The gauges are in.... The AFE stage 1 intake and the DP-tuner got delayed until tomorrow. I was planning on watching the trans temps and pyro close.... I never have had this truck pulling this heavy ( well maybe once many years ago).
1 big question right now... on a stock PCM with stock turbo.... how much boost should I be seeing at various rpm's? I fired it up.... revved it a bit in the driveway.... no boost. I think whiskey tango foxtrot, did I t into the wrong friggin hose? I looked it over, even teased the gauge with a rubber tipped blow gun to make sure it worked. Took it for a short drive and was able to get 15 PSI on WOT.
Old Nov 5, 2008 | 11:08 PM
Izzy351's Avatar
Izzy351
If it's really cold, it takes a while to warm up. If you have the stock gauge, pay no attention to it. It goes to normal after a few minutes, and the "normal" range is like 50-240* (don't quote me on that, but it's close).
Old Nov 5, 2008 | 11:28 PM
bdrummonds's Avatar
bdrummonds
Cant build boost in the driveway, gotta be out on the road.
15PSI is about all the stock tunes will get you. tomorrow with the DP you will see above 20PSI, and unless you have a Overboost annhilator(map fooler) you will set the SES light. You can make one from a compressor regulator, and set it to only flow about 18 to 20PSI to the MAP sensor. the truck will start to defuel if the computer sees 22-24PSI of boost.
Old Nov 5, 2008 | 11:35 PM
Izzy351's Avatar
Izzy351
FWIW, the SES light comes on at 22-23, and defuels at 25. With the mods below, I can easily get over 25, but by all accounts, 25psi is all you want with the stock turbo.
Oh, and the ITP OBA is set to 21 or 22 psi.
Old Nov 5, 2008 | 11:40 PM
willeo6709's Avatar
willeo6709
Jody mentioned this phenomenon when I talked to him when placing the order.... I ordered the no codes tunes becuase it was my understanding he " took out" the section that sets the code to defuel.... if not the overboost regulator sounds easy enough. I think I can even scam a regulator easy.... I know the 4 inch exhaust has a nice whistle compared to stock exhaust.
Old Nov 5, 2008 | 11:41 PM
Izzy351's Avatar
Izzy351
I honestly never heard of that, Leo. That's a new one to me.
Old Nov 6, 2008 | 09:06 AM
TNT in Round Rock's Avatar
TNT in Round Rock
congrats on the gauges ! Hows the trans reading ? ambient temp today was about 50 degrees when I left work. I drove for about 10 minutes before the gauge even got above 100 degrees. Remember, when the weather is cooler, PLUS the trans has a cooler, and no load it may be a bit before the temp comes up.
Brando250
Feb 23, 2014 06:13 AM
Studawg
Feb 3, 2013 07:13 AM
TheFox302
Feb 8, 2011 05:00 PM
Shawn MacAnanny
2004 - 2008 F150
Oct 20, 2009 03:31 AM
dhelm72
May 7, 2005 07:26 PM
