gauges install question...
Old Nov 5, 2008 | 07:48 AM
willeo6709's Avatar
willeo6709
When installing the boost gauge did you drill and tap a port in the intake or did you do the plastic T in the MAP line?
I assume the puprose of drilling the individual holes in the factory a-pillar is to keep the gauge mount cover tighter to the factory part for improved support.
Diesel manor dies not really say, but I assume the pyro gets drilled into the drivers side exhaust manifold?
I got the MBRP exhaust on the F350 late last night, have gauges and a DP tuner F6 to install today. Tomorrow the F350 and the goose goes out to pick up some equipment.
Old Nov 5, 2008 | 08:06 AM
Ponyboychris's Avatar
Ponyboychris
You can do either. Mine is teed into the MAP line but you can also do the AIH delete and tap the plug for your boost line.
I assume the puprose of drilling the individual holes in the factory a-pillar is to keep the gauge mount cover tighter to the factory part for improved support. Yes.
Diesel manor dies not really say, but I assume the pyro gets drilled into the drivers side exhaust manifold? Yes, Driver's side is pre turbo.
Answers in bold.
Old Nov 5, 2008 | 08:13 AM
Izzy351's Avatar
Izzy351
Chris covered it, but to save some stress & time, you can tap the up-pipe instead. It's much easier to put it in the up-pipe and there's no chance of cracking the manifold (something that can happen if you rush it). Here's what mine looks like in the up-pipe.
Are you talking about the little holes up by the top? Then, yes you'll need those. I tried using double-stick tape to keep from drilling it, but it kept coming loose and the little push pegs hold it in place perfectly.
EDIT: One more thing... DO NOT run the tap all the way in!! The tap I used was about 3 threads out for a perfectly snug fit for the port adapter. What I did was run it in & out and kept test fitting the port until it was nice & snug against the pipe. If you don't go in far enough with the tap, the threads won't snug up against the pipe all the way. Go in too far, and it will be loose.
Oh, and I used the tee in the MAP line. No problems so far, but I do want to eventually delete the AIH and us it for the boost gauge tube.
Old Nov 5, 2008 | 08:21 AM
big poppa's Avatar
big poppa
Hey Leo, you got a busy day today, let us know when everythings done and how you make out on the install..
Old Nov 5, 2008 | 08:25 AM
willeo6709's Avatar
willeo6709
the crew is busy adding about 900 square feet onto the shop.... we'll have a service bay again. I have gauges and a MBRP 4 inch for the excursion for when I get the new part of the building closed up. I get to do it twice... only doing the DP on the F350 for the goose for now.
Old Nov 5, 2008 | 08:46 AM
Ponyboychris
Let us know how it goes. You have a full day of truck modding. I'm jealous.
Old Nov 5, 2008 | 09:19 AM
Izzy351's Avatar
Izzy351
If you tow heavy with the DP, you better have gauges.
Old Nov 5, 2008 | 09:30 AM
willeo6709's Avatar
willeo6709
Its a 30' gooseneck dual tandem... 22,500 GVWR. In the next few weeks there are 13 lots to be picked up at a location about 70 miles away....heaviest single item weighs 12,000 lbs. Its an OD grinding machine...the rest of the lots get lighter, but the od grinder is a load by itself. I figure the trailer with that on it will be pushing 20K.
Old Nov 5, 2008 | 10:40 AM
HKusp's Avatar
HKusp
Get that exhaust gauge done asap. You are gonna want to watch that one when towing that heavy.
Old Nov 5, 2008 | 12:43 PM
stangman516's Avatar
stangman516
So the up pipe is thick enough for the threads to grab?
Old Nov 5, 2008 | 02:53 PM
Izzy351's Avatar
Izzy351
Yep. Mine has been in since April or May of '07. Still rock solid in there.
Old Nov 5, 2008 | 02:55 PM
Izzy351's Avatar
Izzy351
Agreed. You'll want to watch the tranny temps also. I'd highly suggest a bigger/aux cooler and aftermarket VB or shift kit if you pull like that regularly, too.
Old Nov 5, 2008 | 04:38 PM
stangman516
Nice. I really wasn't looking forward to drilling through the thick exhaust manifold when i install the gauges this weekend
Old Nov 5, 2008 | 04:53 PM
Izzy351's Avatar
Izzy351
I do suggest you use a nice sharp bit. I went right through it, then tapped it using just some WD40 for lube. I was worried about that part, and it was probably one of the easier steps of installing the gauges.
Old Nov 5, 2008 | 05:01 PM
HKusp's Avatar
HKusp
make sure you lube it and take small bites just like Joe said. The manifold wasn't hard either.
Tranny temp is very important too. I wasn't thinking.
