Comprehensive "Steering Wander" Thread Compilation (and Excursion leaf spring spreadhseet)
Old Aug 4, 2012 | 04:13 PM
  #76
Snowseeker's Avatar
Snowseeker
Originally Posted by C50bart
Whats welded to the front of your crossmember?
Old Aug 4, 2012 | 07:18 PM
  #77
C50bart's Avatar
C50bart
Are you looking at the Y pipe upgrade? That replaced the stock reducer T Pipe.
Old Aug 5, 2012 | 11:50 AM
  #78
Snowseeker's Avatar
Snowseeker
No, the cross member in front of the oil pan. I see the backside of a weld.
Old Aug 5, 2012 | 08:09 PM
  #79
C50bart's Avatar
C50bart
I don't see it. I'll look under the truck but it might be the picture.
Old Aug 13, 2012 | 12:23 PM
  #80
outlw's Avatar
outlw
what are the G's on a 2001 Rear rated at?
Old Aug 13, 2012 | 02:06 PM
  #81
C50bart's Avatar
C50bart
Hey Snow, I don't see a weld but I see a lot of undercoating drip...
Is it the little bubbles, you're referring too? Where the rust meets undercoating?
Old Oct 24, 2012 | 05:57 PM
  #82
bproosow's Avatar
bproosow
Put on the Hellwig rear sway bar last night. As has been said many times, great product, terrible instructions. Only took it for a short drive at highway speed, and the difference was immediately noticeable. Just getting on the cloverleaf to get onto the highway was a much different experience. It does seem now that the rear is stiffer than the front (with regard to roll). I'll be putting the front bar on tonight (hopefully). I'll post back to share the results.
Old Oct 24, 2012 | 06:10 PM
  #83
Stewart_H's Avatar
Stewart_H
Not from personal experience, but from what I've read, the OEM bar is every bit as good, if not better, than the Hellwig front bar.
Why do you want to replace your front bar?
Stewart
Old Oct 24, 2012 | 06:27 PM
  #84
03-6L-X's Avatar
03-6L-X
If your X is a 2000 and you have not changed the "rubber" on the front sway bar that might be why the front seems soft. No need to get a new sway bar. I am going to be replacing mine shortly with Energy Suspension Bushings. Spoke with them today to make sure I was ordering the correct product. Maxwell said that I needed to order:
Front sway bar bushing kit #4.5180G
End link bushing kit (complete kit) #4.5186G
The sway bar bushing that come with the 4.5186G fits a F250 so, that is why you need to order the separate sway bar bushing kit.
Hope this helps.
Old Oct 25, 2012 | 07:01 AM
  #85
Snowseeker's Avatar
Snowseeker
Thats what I am seeing, didn't think undercoating.
Old Oct 29, 2012 | 03:10 PM
  #86
bproosow's Avatar
bproosow
Well, after adding the front bar, I would say it did make a difference. The Hellwig bar is slightly larger in diameter than stock. Is it better than just adding urethane bushings? Probably not much. I agree that the factory bar is a VERY solid piece and probably doesn't need to be replaced. I happened to get a pretty good deal on the Hellwig so I went for it. The rear sway bar is an absolute must-have item. Rather than replacing the front bar, upgrading the bushings on the front would probably yield nearly the same results.
Old Nov 27, 2012 | 02:29 AM
  #87
garryk6's Avatar
garryk6
Hope this helps.
Thanks for the part numbers!
Just read all 6 pages, and this is Great info!
Thanks!
Garry
Old Nov 27, 2012 | 01:09 PM
  #88
Stewart_H's Avatar
Stewart_H
Only 3 pages for me.
I have the number of posts per page maxed out in my User CP is why. Much easier that way.
Stewart
Old Apr 25, 2013 | 09:28 AM
  #89
C50bart's Avatar
C50bart
Stewart
http://s1078.photobucket.com/user/c5...rd%20Excursion
Just a pictorial of the V & B mod and a Western MVP custom mount to accomidate the new height.
Stewart, can you please edit my posts within this thread. I have added new pictures of my Ex with a new slide show link for the Mods. The link above is a direct link. If it's worth the troubles could you replace the dead picture links with this link. I couldn't edit each post myself. Thanks.
Old Apr 25, 2013 | 10:11 AM
  #90
Stewart_H's Avatar
Stewart_H
Done.
Stewart
