Comprehensive "Steering Wander" Thread Compilation (and Excursion leaf spring spreadhseet)
Old Jan 23, 2012 | 11:08 PM
  #46
VQT's Avatar
VQT
To the top
Old Jan 28, 2012 | 12:30 PM
  #47
Stewart_H's Avatar
Stewart_H
Bump.
Added Rich's thread to my first post.
Stewart
Old Feb 24, 2012 | 11:16 PM
  #48
Pitcrw6's Avatar
Pitcrw6
This thread has taught me so much about springs...wow. I guess I will be on the look out for used springs. Thanks guys
Old Feb 24, 2012 | 11:29 PM
  #49
Stewart_H's Avatar
Stewart_H
Glad the thread has helped.
Stewart
Old Feb 25, 2012 | 08:27 AM
  #50
wpnaes's Avatar
wpnaes
Here's an example:
2001 Ford F-350 Front Leaf Springs
Old Mar 14, 2012 | 06:52 PM
  #51
Bigdaddybus's Avatar
Bigdaddybus
After some searching for over an hour I can not find the anwser to the following.
What is the distance from the center of the hub to the bottom of the fender on a stock 4wd Excursion both front and rear?
What is this distance with V code springs in the front? B's and stock blocks in the rear?
I bought an 05 4wd PSD X in January, and I am trying to figure out what I have. My measurements are 23.25" front and 24.25" rear.
Stewart, is this stock or do I have V codes in the front from the previous owner? Thoughts?
Old Mar 14, 2012 | 07:45 PM
  #52
robert_l_ross's Avatar
robert_l_ross
I'd consider taking a pic of the rear end. Visually you can't tell the springs on the front - V codes and stock both have 2 leaves. Nearly everyone who does V codes in the front do something to the rear - blocks, RAS, B codes, Modified B, etc.
Here is a shot of the stock rear end on an Excursion:
Note the size of the block and the anti-wrap bar. If you have a bigger block, a bottom overload leaf (goes fore and aft of the axle, not just fore) or a coil spring assembly on the top of the leaves, then the rear has been modified (and a good chance the front was modified as well if you are sitting level or with a rear-high rake).
Stock front springs:
V code fronts:
Note the leaves are visually the same - thickness, etc. Mine look a lot different since the new ones were clean when put on, but next to one another when off of the truck, they have the same arc. Makes it very difficult to tell the difference.
I haven't seen any posts with measurements to the center of the hub...only to the ground. Here were my measurements -
Pre Spring measurements:
Driver Front: 37 1/8
Passenger Front: 37 1/4
Driver Rear: 38
Passenger Rear: 38 1/2
New springs (the truck was facing the opposite direction in the driveway):
Driver Front: 39 3/4
Passenger Front: 39 3/4
Driver Rear: 40 1/4
Passenger Rear: 40 3/8 (uneven driveway or cladding is off a hair?)
Old Mar 14, 2012 | 07:47 PM
  #53
robert_l_ross
Also, your dizzle will sit a touch lower than my V10 since your motor is heavier.
Old Mar 14, 2012 | 07:53 PM
  #54
Bigdaddybus
Thanks Robert! Since my truck has oversized wheels/tires and I didn't get stockers with it, I was looking for the center hub measurement.
So I went out to the garage and measured 39.5" front and 40.5" rear to the wheel well molding with 275/65/20's.
The rear suspension looks Just like your stock picture with hollow block, and antiwrap bar.
The front was a surprise when I found part number 3C34-5310-AJA, which are not Ford V code part numbers, but close. aftermarket i assume.
Now to upgrade these reflex shocks!
Old Mar 14, 2012 | 08:40 PM
  #55
robert_l_ross
Don't trust any front spring part numbers stamped on them...to date no-one can produce a comprehensive list of part numbers vs spring code. I thought I read even V code stamps don't always match other V code springs.
Old Apr 8, 2012 | 11:06 AM
  #56
C50bart's Avatar
C50bart
I would like to thank all the guys that have provided the V & B Mod Swap information. After 2 Days of knuckle busting wrench turning labor, while having Strep throat (Thanks to my kids ), I've completed the front & Rear suspension .
I'll post up details but I wanted to share Before & Afters pictures.
http://s1078.photobucket.com/user/c5...rd%20Excursion
I think it's time for 35" wheels....
Here's to you guys!!!
Last edited by Stewart_H; Apr 25, 2013 at 09:53 AM. Reason: Per OP's request to replace dead pic links
Old Apr 8, 2012 | 09:51 PM
  #57
crmarshall's Avatar
crmarshall
While tightening my steering box I notices something I found interesting. I could not get the play out of the wheel by tightening the box. I had my son "rock" the wheel back and forth while I held each steering component to check for play. While doing this I noticed the entire axle with the springs was moving under the vehicle(side to side). The bushings in my stock Ex springs are so soft that they were/are allowing the axle to move 1/4" side to side. The bushing was not sliding on the bolt, just flexing. I also noticed that the sag of the stock springs had decreased the angle of the track bar and pushed the springs to the passenger side of the spring perches on the front of the spring. This was causing the passenger spring to contact the outside of the spring perch and caused a clunking sound when I hit a bump. I had replaced my sway bar bushing (which were shot) but still had the clunk. I am putting V codes in this week.
Old Apr 9, 2012 | 10:30 AM
  #58
jwronski's Avatar
jwronski
With 5 inches of additional height at the back end, I am assuming that you did a little more mods than just the Modded B's? I see the dual shocks in the front. What else did you do? Looks good.
Old Apr 15, 2012 | 09:34 AM
  #59
white Buffalo's Avatar
white Buffalo
Looking good man! I know the dohnut tire feeling. Drove mine around for 6 months after the lift with the stock tires while trying to save up some $ and decide on rims & tires.
Take your time and do your homework on tires so you don't end up rubbing.
Old Apr 15, 2012 | 09:36 AM
  #60
white Buffalo
Looking at the 3rd picture it looks like he also added a hanger kit.
