headers
Old Nov 3, 2008 | 03:34 PM
  #31
JBradley500's Avatar
JBradley500
Originally Posted by 99sbm
thanks. i wasnt sure if it was a 3 or a 4. in my old CJ5 it had a D18 or T18 something like thar and everyone always refered to it as a 3spd, granny low. and as far as my truck goes you pretty much have top take off in low or it just bogs down (stupid 38's, lol) and 4th gear is pretty much useless under 55mph
t-18 is the borg warner granny low transmission. thats what my f250 has in it too.
Old Nov 3, 2008 | 04:53 PM
  #32
99sbm's Avatar
99sbm
Originally Posted by northeaster79
I forgot to give you the part number for the dynomax headers its.WLK-85057.dynomax blackjack long tubes.1 1/2" primaries,3" collectors.
thanks. i got the pix and it looks like they will work. greatly appreciated
Old Nov 3, 2008 | 04:55 PM
  #33
99sbm's Avatar
99sbm
that was what was in my jeep. along with a dana30F, dana 44R, dana 20 Tcase, and amc 360.
Old Nov 3, 2008 | 06:12 PM
  #34
1977f150xlt's Avatar
1977f150xlt
full length 302 headers won't work, trust me i went through that! and i ended up using late 80s mustang stock shorty headers, you got to get the ones with the nickel stainless steel alloy headers, they last forever! plus there cheap, and you can then route the exhaust to meet the headers, the full length headers run into the front drive shaft! i have the stock 80's ford shorty headers bolted on my truck right now, i just have to get my dad to bend the exhaust tubing up to the headers and get some trick magnaflow mufflers! and some nice stainless tips with dual pipes in front of the rear tires on each side! and i might put flamethrower kit in to boot!
Old Nov 3, 2008 | 09:40 PM
  #35
77Explorer's Avatar
77Explorer
Welcome over micheal
(this is Russ BTW)
A set of mustang shorties should do you just fine!
Old Nov 3, 2008 | 10:33 PM
  #36
99sbm's Avatar
99sbm
(this is Russ BTW)
that was the plan, if i couldnt find full lengths. so when you wana see this beast?
Old Nov 3, 2008 | 10:34 PM
  #37
99sbm's Avatar
99sbm
and learn to spell my name. lol
Old Nov 6, 2008 | 08:20 AM
  #38
77Explorer's Avatar
77Explorer
Old Nov 17, 2008 | 03:45 PM
  #39
99sbm's Avatar
99sbm
hate to keep beating a dead horse, but i was looking at the truck today and the driverside looks almost impossible to put a standard shorty header (from like a stang) on. it almost drops straight down between the last 2 cylinders and the "Z" bar would be in the way for a rear exit header. the stock manifold goes down and connects to the exhaust which runs under the oil pan to the passenger side. now my question is (and forgive me for my ignorance) will a set of headers from a full size bronco work? i found set that say they are designed to clear the clutch and steering linkage and the pictures look like they might work. Early Bronco Ford exhaust systems, ceramic and metal headers, dual exhaust systems, V8 header, kit, bolts what do yall think. there has to be atleats one person out there with a 4x4 truck with a 302 and headers, right?
Old Nov 17, 2008 | 04:31 PM
  #40
KFX400's Avatar
KFX400
The headers off of an early model bronco will not work either i tried it last year and it failed. They dump right out on top of the drive shaft. There is a couple of older threads on this if you search for them. I gave up and stuck with the manifolds.
Old Nov 17, 2008 | 05:05 PM
  #41
99sbm's Avatar
99sbm
but with 8" of lift would that still be an issue?
Old Nov 17, 2008 | 05:14 PM
  #42
KFX400's Avatar
KFX400
Mine had a six on it when i tried I am not joking when I say it drops right down on the driveshaft. I had to take the driveshaft out of my truck to put the headers on then when I tried to reinstall it was a hopeless cause that is why I am take it out and putting a 351C in it this time.
Old Nov 17, 2008 | 05:35 PM
  #43
1977f150xlt
i plan on getting a exhaust tube bent to reach up to the stock mustang shorty headers, heck you can go any way you want! it will be tight around the front drive shaft, but it can be done, trust me i have my stock 80s headers bolted in my 77 f150 4x4 with a 302 and AOD tranny, and the exhaust pipe can be bent to fit, i will post pictures when i have the exhaust tube bent and installed.
Old Nov 17, 2008 | 07:01 PM
  #44
Colo79Ford's Avatar
Colo79Ford
What about the engine swap headers for bronco 2's and ford rangers with 302's? I have no clue if they would work or not, heres a link....
Bronco II 4x4 302 Headers
jrcustoms
Sep 6, 2012 09:26 AM
93truck
Jan 20, 2011 10:29 PM
gingerbreadmaniac
Jun 21, 2009 02:02 PM
JaredMackall
1983 - 2012 Ranger & B-Series
Sep 10, 2003 08:35 PM
