BD Eletronic Boost builder extra 50-80hp?
Old Apr 19, 2010 | 05:56 PM
  #61
DevilDocTater's Avatar
DevilDocTater
Master of Disaster
So do you get a lot of black smoke with take-off since it is adding fuel to the low end?? Im on stock tuning, but ive got new HG's and ARPS. I tow a lot is the reason i dont run a tuner. Im thinking about trying this mod out.
Old Apr 19, 2010 | 09:20 PM
  #62
Zmann's Avatar
Zmann
run a real tuner and tow
Old Apr 19, 2010 | 09:54 PM
  #63
DevilDocTater
Master of Disaster
From all the recommendations, when towing heavy its not advisable to run a tune. Most i have talked to said take it back to stock. I just dont wanna have to switch back and forth with tunes. Im not lookin for huge power but it would be nice to not have that initial dead space
Old Apr 19, 2010 | 11:28 PM
  #64
Lubbockguy1979's Avatar
Lubbockguy1979
I run less egts and get better mpgs along with better power with a tow tune. I do not run a aggressive tune for towing though 60hp or less.
Old Apr 20, 2010 | 06:05 AM
  #65
DevilDocTater
Master of Disaster
Right on, is there a weight limit on towing with a tune? EGTs were my main concern with towing, second was i dont mind some black smoke but i just dont want a ridiculous amount. Also, im not sure how many miles are on my clutch, i hear of guys with manuals putting tuners in then needing a clutch?
Old Apr 20, 2010 | 08:43 AM
  #66
Zmann's Avatar
Zmann
it depends on the tune ,, some tunes are specifically made for towing and can help with egt's.downhill speed holding etc
Old Apr 20, 2010 | 08:58 AM
  #67
Lubbockguy1979
Depends on the tune for weight. I would say 60hp over stock or less in a heavy tow designed tune. Some have a 80hp tune for towing. Tunes with a lot of smoke are generally performance oriented not tow tunes.
Old Aug 20, 2011 | 08:36 PM
  #68
Newfee's Avatar
Newfee
so if im running a 6L with edge juice with attitude that allerady plugs in to that sensor then can i use this product or can it be inline i havent seen boost hit over 25 psi yet
Old Aug 20, 2011 | 09:13 PM
  #69
Zmann's Avatar
Zmann
you don't want to boost more if you aren't studded
When I had My edge before I realized they were bad for a 6.0 I could fine tune the parameters through the back user menu's and have the edge display recall tell me I hit 31psi
Old Aug 24, 2011 | 01:38 PM
  #70
dave at BD Power's Avatar
dave at BD Power
Former Vendor
Boost and Abuse can blow a h/g but can easily be avoided with a little user responsibility. We have done over a 150 head gasket jobs in that last 2 years and 99.5% of them have been caused by EGR Cooler Failure, not a chip, tuner of boost builder.
My 2 cents
Dave
Old Aug 24, 2011 | 03:19 PM
  #71
Rob.D's Avatar
Rob.D
My 2 cents
Dave
That's why everyone should be monitoring there EOT & ECT Delta and not exceeding 15*
Old Aug 24, 2011 | 10:14 PM
  #72
dave at BD Power
Former Vendor
Absolutely and some of the newest calibration will trigger a code for that now on certain strategies... wonder why Ford did not do that sooner. hmmmmm
Old Aug 25, 2011 | 12:34 PM
  #73
Nitrous's Avatar
Nitrous
My 2 cents
Dave
How many of those 150 had the round 2003 type egr cooler and how many had coolant filters would you say?
Old Aug 25, 2011 | 05:09 PM
  #74
dave at BD Power
Former Vendor
I would say about 10-15% were early 03, can not say any of them had coolant filters?
Dave
Old Aug 25, 2011 | 11:37 PM
  #75
sullyt28's Avatar
sullyt28
Hey Dave,
Common issue with 6.0 EGR delete is lower PSI numbers 21~22 etc. at WOT. Several posts written with no explanation or cure.
Boost builder do anything to correct this issue ?
