Removing EBPV Linkage With Pics
Old Oct 29, 2008 | 11:01 AM
PaysonPSD's Avatar
PaysonPSD
Exclamation Removing EBPV Linkage With Pics
While removing my turbo I couldn't figure out how to release the EBPV linkage from the turbo pedestal. Of course I came to FTE for help. It was so simple once I new what needed to be done.
This is the sliding clip that holds the valve actuating rod to the back pressure valve tang. Clip is on the underside of the flat end of rod. It is under and at the back of the turbo and cannot be seen without a mirror. Just feel for and simply slide it back and let the rod drop down or push it down and off the pin. I used needle nose vice grips to slide the clip back.
Here's a view of the underside.
Hope this helps someone at sometime.
Old Oct 29, 2008 | 11:07 AM
03_PSD's Avatar
03_PSD
Nice pics Robin. LOL now I know where the clip is!
Old Oct 29, 2008 | 11:08 AM
mueckster's Avatar
mueckster
Robin,
Thanks for the pictures. It will help those who have not done this to have a better understanding of how the clip releases.
Sorry, I can't rep you for this. Still on a 'time out'.
Old Oct 29, 2008 | 12:26 PM
87 F-150 I6's Avatar
87 F-150 I6
Thanks for telling us, and great pics
Old Oct 29, 2008 | 12:40 PM
Action4478's Avatar
Action4478
Originally Posted by mueckster
Robin,
But I can ....No time out here ...
Saved the Pics ,too...
Old Oct 29, 2008 | 03:18 PM
PaysonPSD's Avatar
PaysonPSD
Thanks Guys. Like they say "A picture is worth a thousand words".
And I'm glad my new pedastal is non-EBPV.
Old Oct 29, 2008 | 03:23 PM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
To Mod the ped., cut the arm off with grinder, sawzall-metal blade, or hack saw. Pull out lock washer from otherside and remove everything from the inside. Replace cover and lock washer. Seal off hole from arm and done. Will fill back up with oil to lube turbo still. Don't forget to replace O-rings when reinstalling ped. and turbo. Most common leaks are right between ped. and block.
Old Oct 30, 2008 | 12:05 PM
strokersace's Avatar
strokersace
Nice pics Robin! Mine is going to have to come out soon as it's leaking just like yours looks like yours. I'm going to try and hold off till I get my van turbo rebuilt and the non EBPV pedestal.
Reps sent!
Old Oct 30, 2008 | 01:06 PM
PaysonPSD's Avatar
PaysonPSD
Reps sent!
Thanks Ryan. I never had a real oil leak but the back of the pedastal was pretty grimey. I'm also upgrading to a new turbo. Nothing wrong with the old one other than it is and early 99. I'm also upgrading to late 99 3" plenums, spider, non-EBPV pedastal and bellowed up-pipes. A work in progress. All the old stuff is out. Hope to get the new installed in the next few days. Do to inexperience I'm really slow at this kind of work. Taking a couple of days off because my back and shoulders are sore.
Old Oct 30, 2008 | 01:17 PM
a-rod's Avatar
a-rod
Good pics, I fought this ******* little clip as well
PaysonPSD
66
Dec 30, 2016 08:09 AM
PaysonPSD
29
Dec 25, 2016 10:06 AM
PaysonPSD
13
Jul 1, 2010 01:05 AM
PaysonPSD
21
May 6, 2010 07:05 AM
PaysonPSD
36
Jun 9, 2009 10:42 PM
