03 Front end to early 99 SD
Old 10-28-2008, 12:19 PM
craziejoker
craziejoker is offline
craziejoker is starting off with a positive reputation.
Alright, just wondering if anyone here has had any luck changing the whole front end assembly off a 03 super duty to an early 99? I got a line on one and I checked my interchange and it will work,the front end assembly is the same,the hubs i know are different. Any ideas? Any problems i dont see?
thanks
Old 10-28-2008, 01:05 PM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
You want to swap the whole axle? Yes it can be done, but you'll also need the track bar bracket and track bar.
Old 10-30-2008, 01:08 PM
craziejoker
I figure it will be easier to change the whole thing,as I grabbed the whole assembly from the yard and will just bolt it in.
Old 10-30-2008, 01:48 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
If the swaybar from the 03 bolts up to the early 99 axle housing then that won't be a problem. Just something to consider. O3 has slightly larger swaybar. The rotors and calipers on the early 99 are also different I do believe. Only bringing this up in case there is a problem swapping the 03 rotors and calipers to the 99 axle.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
