Water Pump Plug Tip
Old May 5, 2010 | 10:41 AM
PaysonPSD's Avatar
PaysonPSD
Exclamation Water Pump Plug Tip
Put in a new water pump yesterday. All went well except when I went to remove the plug to put in my ISSPRO coolant temp sender. The plug in the water pump had a 5/16" square drive. I have read that some have run across this before (my last water pump had an allen head plug) and had to use a piece of 5/16" square stock to get that plug out. I didn't have any 5/16" square stock so I was going to grind down a short 3/8" extension but then I found that the square end of a nail punch is a perfect fit.
Old May 5, 2010 | 11:05 AM
riverrat41's Avatar
riverrat41
Thanks for the heads up
Damn rep police
Old May 5, 2010 | 11:26 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
When there's a will..... Good job Robin. I found that a piece of 5/16 square stock will fit just right in a 3/8" 12 point socket in order to use a ratchet.
Old May 5, 2010 | 11:31 AM
PaysonPSD's Avatar
PaysonPSD
I slipped a 3/8" Gearwrench (box end ratchet wrench) over the punch and out came that plug.
Old May 5, 2010 | 11:40 AM
nhill2090's Avatar
nhill2090
for those that have ever wondered why tool places sell square drive sockets of various sizes, this applies here.
Also happens to be why i have a set in my tool box
Old May 5, 2010 | 03:45 PM
Ponyboychris's Avatar
Ponyboychris
These are the things that drive me nuts when working on my truck. Just when you think you have all the necessary tools and supplies to do a certain job, something like an odd-ball fitting makes you scramble for a solution. Thanks for the heads-up, Robin.
Old May 5, 2010 | 04:42 PM
nhill2090's Avatar
nhill2090
thats why you should keep your local snap on dealer on speed dial
Old May 5, 2010 | 04:58 PM
ron's power stroke's Avatar
ron's power stroke
nice tip Robin
square drive and torques are very handy to have..i have both from a screw driver size all the way up in my box...
Old May 5, 2010 | 06:32 PM
PaysonPSD's Avatar
PaysonPSD
Thanks Guys.
Sometimes we have to improvise. I wasn't going to drive to town to get something I probably will never need again. Hell, I've got 3 nail punches that can double as 5/16" drive.
Old May 5, 2010 | 06:48 PM
maevans's Avatar
maevans
Another great tip and pic's from Robin. Thanks
Old May 5, 2010 | 07:53 PM
PaysonPSD's Avatar
PaysonPSD
Thanks Mark.
Old May 5, 2010 | 08:22 PM
flatbeder's Avatar
flatbeder
Thanks for the heads up and the nice pics as always Robin.
Old May 5, 2010 | 08:35 PM
Stewart_H's Avatar
Stewart_H
Excellent!
Rep jail otherwise...well, you know!
Stewart
EDIT: I spread some, so I WAS able to get ya!
Old May 5, 2010 | 09:03 PM
spdmpo's Avatar
spdmpo
Always good to have the right tools, but no way was I going to spend that kind of money for a 1 time deal. Much cheaper to grind down a cheap chinese extension. But the nail set is even better idea.
Old May 5, 2010 | 09:14 PM
PaysonPSD's Avatar
PaysonPSD
Thanks Big Joe and Stewart.
Exactly how I felt Keith.
