Blown Turbo Part II, With Pics
Here's some pics of the blown TN-BB.
When the seal went the turbine wheel turned into an oil pump. Lost 7 quarts in 45 miles, doing 35 MPH. 7 quarts is what I added today to bring it up to the full mark. During those 45 miles I continuosly monitored LPOP, HPOP and an after-market coolant temp gauge. They all remained normal and truck ran OK except for the huge plume of white smoke. I doubt I would have made it another five miles before she shut down.
Pic with exhaust outlet removed. Had to put the exhaust outlet on the new 38R.
The next 2 pics show how much play was in the compressor wheel. The bearings are shot.
Wheel lifted up.
Wheel pushed down.
With compressor housing removed.
Compressor housing from the inside. Notice machined groove. Explains the weird wear pattern on the compressor wheel.
Now I wonder if the bearings went and then the seal, or if the seal went and then the bearings. Which came first? The chicken or the egg. I'm thinking the bearings went first. What do you think happened first?
Wheel lifted up.
Wheel pushed down.
Parts for this Turbonetics are hard to come by since it has been discontinued, especially the bearings, so I wouldn't even think of trying to salvage it. I'd like to do a post mortem but it will have to wait until I get the proper 12 point socket for the turbine wheel.
The polished compressor housing and the ceramic coated turbine housing are probably still useable.
It was a Turbonetics Ball Bearing. Part #TN-11117-BB.
I agree with your 2 cents. The bearings went and the wobble took out the seal.
Happy Belated Birthday by the way.
I don't know if I would want to re-use that housing.
Aluminum is a lot softer than that intake wheel and I wouldn't be surprised if the wheel carved away some of the material.
That would increase clearance between the wheel fins and the housing which would lower turbo efficiency, IMO.
Don't know how many HP it was subjected to.
When I get it apart I will do that.
Very nice offer Jock but I have already installed a new 38R.
PaysonPSD
66
12-30-2016 08:09 AM
PaysonPSD
15
07-12-2010 12:14 PM
PaysonPSD
36
06-09-2009 10:42 PM
