Need to pull axles? Need some tips..
Old Oct 28, 2008 | 07:42 PM
78ford351m's Avatar
78ford351m
I need to pull all the axles off a 79 shortbed. I sold them on ebay and need to get them out. How hard is this? This is a sitting frame.
Jason
Old Oct 28, 2008 | 08:28 PM
75F350's Avatar
75F350
Are you taking the axleshafts out of the rear axle housing?
This only requires the removal of the drums, and the bearing reatainers. $ bolts on each side, and the axleshafts will pull out.
Perhaps you have a 4 wheel drive, and you are pulling the front shafts also????
Remove hub assembly, and spindle, then axle shafts will pull out.
Draining the fluid first is a good idea, or things will get messy.
Maybe, you are removing the entire axle housing as a complete unit?
Remove driveshaft, shocks, e-brake cables, spring plates, and remove entire axle assembly.
Same is true for front if 4wd, only one has to also remove the steering linkage.
That about sums it up I guess.
Old Oct 28, 2008 | 08:29 PM
86F250BIGBLOCK's Avatar
86F250BIGBLOCK
What axle is it? The whole axle housing, or just the axle shaft? Both are pretty easy to do, more information and we'd love to help you!
Old Oct 28, 2008 | 08:30 PM
86F250BIGBLOCK
You beat me to it! Oh well he said it better anyways haha
Old Oct 29, 2008 | 07:12 AM
78ford351m's Avatar
78ford351m
He just wants the axles themselves, so I guess I'll just pull the shafts. I'll let you know. Thanks guys.
Old Oct 29, 2008 | 10:22 PM
masterbeavis's Avatar
masterbeavis
If you were pulling the complete assembly, and are going to junk the truck, here is what I do.
I drag the truck onto the trailer. I use a torch or a sawzal to cut the Ubolts, brake lines, ebrake, steering. Have driveshafts out already. If anything is attached, cut it. When the ubolts are cut, they will pop. Finish them off by whacking em with a hammer to clear the tubes. Strap frame to the trailer very well, haul to the junkyard. Have them lift the body off of the trailer, axles stay behind, strap the axles, go home.
If you were not planning on junking the truck, I put the truck on jackstands, and a jack under the axles, and support their weight. Ubolt everything except the ubolts. Pull the bolts from the shackles(from the leafspring) and lower the axle to the ground. Ubolt the Ubolts, roll axle from the truck. Installation is reverse from removal. Position the axle on the ground, under the springs, hook the ubolts up. Raise the axle back into position and put the bolts back into the shackes. I have tried other ways, this is the easiest IMO.
Old Oct 30, 2008 | 05:59 PM
80F100man's Avatar
80F100man
Sorry if I'm hijacking the thread but, will a dually rear axle bolt right up to my F100 driveshaft, springs, u-bolts etc.? thanks guys........
Old Oct 31, 2008 | 10:58 PM
masterbeavis
Probably not. Spring perch widths might be different, driveshaft for sure will need shortening, Ubolts will be the incorrect size. Ebrake cables *might* be different as well.
Old Nov 1, 2008 | 11:10 PM
78ford351m's Avatar
78ford351m
Got it done. Piece of cake. I pulled both the whole dana assembly and rear assembly. Took about 2 hours. Thanks guys.
noplugs4me
All Things Towing
Feb 3, 2014 03:53 PM
Jason Trimberger
Aug 29, 2012 05:35 PM
78ford351m
41
Feb 18, 2008 07:38 AM
RCrawler
Sep 28, 2006 05:58 PM
laka
Jan 22, 2004 10:36 AM
