I need some help trying to figure out what these axles are called.
They have timberin style air bags and just bolt onto the side of and bottom of the frame. I saw them a few years ago on a TV show. I need new axles on my utility trailer and was thinking these might be the way to go.
Please help me out RV_TECH and others. Thank you. -Jason
Sorry man,
My catalogs are all RV stuff, standard beam axles. If you have a picture, I am sure folks in this forum will help you track em down!
Have you even talked to anyone that has the hybrid system, the rubber blocks on my Mor/Ride RE system are starting to tear and I was looking at the Dexter hybrid sysyem, I like it because I can bolt it on.
has anyone built there own? for example using vintage VW bus front torsion beams? so they would lay horizontal, instead of vertical, re-indexing beams, & widen axle as needed for project, and rebuild brake system & using a brake actuating hitch. just an idea I have tossed around in my head.
