The primary reason why aircraft, especially large aircraft use nitrogen in the tires is because that gets rid of the oxygen inside the tire- Usually between the scuff of landing and the shear weight on the tire, the temps inside can get very close to the ignition point of the rubber. Add to that the fact that the rims are commonly magnesium (flammable and burns violently), and you have a good reason to have an inert environment.
In your own personal car, it's a wash. Most people who are concerned enough to run nitrogen filled tires probably won't gain anything noticeable from it- They'll either trade in their car before the tires wear out under normal use, or have the tires replaced before the tread life is up.
If the temp of the tire on the inside gets hot, well then the outside of the tire must be even hotter. And it's surrounded by what - air. And I already posted the heat capacity of air and nitrogen are quite similar, so how is the tire going to stay cooler?
Let me know how a mag wheel burns, too. Very hard to ignite/burn solid pure mag, much less an alloy like AZ-91 or AM-60 (used to be a chemical engineer at a magnesium production plant) that has significant amounts of aluminum in it. It has to be shredded into ribbon form for easy ignition. That fallacy is why magnesium is rarely used in automobiles, even though VW made millions of Beetle engine blocks out of it.
Ford used magnesium for manual trans bellhousings for several years. It was quite a bit lighter than aluminum, but more costly. That's why Ford went back to aluminum
Yeah and there are some pretty slick members around here as well... even though some are just spinning their wheels and smoking their way to an early burn out.
I'm not going to tell my wife about this topic, I think it would rubber the wrong way. I'll just be content with staying in the room by myself, staring at the white walls.
