window motor
Old Oct 27, 2008 | 01:14 PM
stephenfaustin's Avatar
stephenfaustin
window motor
I am trying to put in a new drivers side widow motor, but the motor needs to be installed with rivets. I have never used a revit gun before so any advice(what size rivets, etc) would be helpful. Thanks.
Old Oct 27, 2008 | 01:28 PM
skaterbro's Avatar
skaterbro
Hmmm.... it should just be three small bolts holding the motor in. You should be able to see on of the bolts through the opening near the motor. The other two can be accessed by drilling two small holes.
As far as i know, just the regulator is riveted to the door.
Old Oct 27, 2008 | 01:29 PM
andym's Avatar
andym
Skip the rivets and use some short bolts and nuts. I went through the same thing, but could never find the right rivets to work with the holes in the door. I gave up and used bolts.
The motor is bolted to the regulator, but the regulator is riveted to the door.
Old Oct 27, 2008 | 02:39 PM
Conanski's Avatar
Conanski
+1.. you'll need a big commercial riveter for these things and it's simply not worth it. Get some automotove fasteners with captive nuts and cut the bolts down so they don't contact the regulator...
Old Oct 27, 2008 | 03:32 PM
skaterbro's Avatar
skaterbro
See, now the OP said he's replacing the "window motor". What i get out of that is that he's replacing just the motor. Why would he want to go through the hassle of removing rivets for the regulator?
Old Oct 27, 2008 | 05:53 PM
andym's Avatar
andym
Don't know... but if he's talking about rivets then he's removing the regulator.
Old Oct 27, 2008 | 06:44 PM
jr32560's Avatar
jr32560
guess he can't see the bolts in the motor-should be 3 dimples that have to be drilled out so you can see the bolts-that is how my 88 and 90 were!
Old Oct 28, 2008 | 05:34 AM
ccecilm2's Avatar
ccecilm2
See this link for window motor replacement:
https://www.ford-trucks.com/forums/7...otor-swap.html
79F250isalive!
Feb 1, 2015 10:17 AM
ed2hess
23
Jan 7, 2011 02:08 AM
z1121jack
Aerostar
Jun 16, 2009 09:29 PM
david1951F1
May 19, 2005 08:20 PM
jethro
Mar 28, 2001 10:16 PM
