Aerostar Ford Aerostar
window lift motor
Old Jun 15, 2009 | 08:39 AM
z1121jack's Avatar
z1121jack
window lift motor
My driver's side window is stuck in the down position. I think it is the window lift motor.
How do I change the motor? I think I have to drill out the rivets and replace them with bolts with the new motor. But, I cannot see the motor so I don't know which rivets to drill. Help please.
Old Jun 15, 2009 | 09:07 AM
VanGo's Avatar
VanGo
Check the manual. You don't drill any rivets, you drill out the dimples so you can access the bolts behind the sheet metal. That's how my '93 is. It's actually a very simple job, I just did mine a few weeks ago. Bought the new motor from rockauto.com. I think the instructions with the motor said how to do it too.
Old Jun 15, 2009 | 11:21 AM
1Aauto's Avatar
1Aauto
Former Vendor
Not sure what year you have but if you need a motor too here's a link to the Aerostar ones on our site.
Aerostar Window Motor
Old Jun 15, 2009 | 03:54 PM
Pablo-UA's Avatar
Pablo-UA
If motor stucks, the only way is to drill riviets, and push up window to get power lift assembly out. Then, you may unscrew 3 bolts with 8mm socket to remove motor, to take motor appart just unscrew 2 long bolts with 8 mm wrench ore socket. you may have bad brushes, ore motor rotor with worn lamels. well, sometimes protecting thermal switch fails.....
Old Jun 16, 2009 | 04:17 PM
tom_foreman's Avatar
tom_foreman
You don't have to drill the rivets out. There are a lot of threads here on how to do it. Just do a search.
Old Jun 16, 2009 | 09:29 PM
VanGo's Avatar
VanGo
That's what I said Tom, are we wrong. I just did mine. Maybe some years are different?
RRranch
29
Jun 24, 2017 12:13 AM
PapaBearYuma
Mar 18, 2017 11:16 AM
.Artisan.
Jul 4, 2016 01:29 PM
whirredup
Aerostar
Nov 2, 2006 11:41 PM
FalconEddy
Aug 13, 2004 08:17 PM
