Iam begining to believe the 3,8 is from hpop oil
or fuel and the grey sensor unmasks it. The 3 and 8 fire
right after a cyl has fired in the same bank (head).
Would be nice to see the #s with an HX also.
I still have the LL, and also have the HPX and am getting ready to install the DFA RR as an upgrade to my CCK, then I can figure out how to use my newly purchased AE for the IPR duty cycles, rotational velocities, and the CCT's.
I also still have a couple of brand new gray CPS units, one used gray CPS, and one used black CPS, none of which have given me any trouble.
...hehe... if that's not a mouthful of acronyms, I don't know what is!!
Bill
I've still got the offending CPS. Send me an HX and I'll be glad to.
I'm pretty sure others have seen the same issues even with the crossover, including those without the LL. Interesting observation though. We'll need to wait for others to chime in who have seen similar issues.
So what does rotational velocity mean to me? I get that the numbers are different but what difference is it?
Borrowed from Dennis at ITP
For 99-03 7.3L, another way to use AutoEnginuity to see if there are problems with a particular cylinder is to monitor the "Cylinder x Change Rotational Vel" or "Percentage of Crank Deceleration" PID (also commonly called PERDEL). This PID exists for all 8 cylinders and is a representation of crankshaft velocity change (decrease) at the time the cylinder is firing. Ideally, these should all read 0%. Any cylinder consistently reading more than 3-5% change in rotational velocity is suspect and should be further examined. Note: Engine should be fully warmed up before checking PERDEL data.
I read many threads on the subject of this CPS sensor.
I want to ask a question that I have seen as yet.
the question is, What is the sensor?
Is it a magnetic pickup, that measures pulses from the cam gear?
Has any one measured the actual square pulse voltage and amplitude generated from the sensor?
Has anyone experimented with changing the gap between the sensor and the cam gear thereby changing the voltage generated?
Inquiring minds want to know!
thanks, Nick
Sorry Nick, I'm not smart enough to figure out how to take the readings you're talking about, but I'll share with you what I do know.
The manual says
<title>Camshaft Position (CMP) Sensor</title><link href="V2C%7Eus%7Een%7Efile=V2Cstyle.htm%7Egen%7Ere f.htm" type="text/css" rel="stylesheet">Signal Functions The camshaft position (CMP) sensor is a Hall-effect type sensor that generates a digital frequency, as windows in a target wheel pass through its magnetic field. The frequency of the windows passing by the sensor as well as the width of selected windows allows the powertrain control module (PCM) to detect engine speed and position.
So, yes it's a magnet picking up grooves in the cam gear. The OBS trucks have used shims in the CPS, but as I understand it, that was to prevent contact during cam walk, not to change anything generated by the sensor.
Here's a picture of the grooves (squares) in the cam gear. You'll note the one larger square and one skinny square, which notes the #1 & #4 cylinder position for timing purposes.
To measure the actual signal you have to place a meter across the two leads that are attached to the sensor, without opening the circuit. You might be able to use a digital meter to measure voltage, but probably need a scope to see the pulses generated, since the pulses would be of variable frequency. It would be interesting to do some experimenting to see the actual raw signal from the device, rather than the interpretation from a reader and software.
nick
Do you have an oscillascope Nick? I don't, and I doubt a meter would give sufficient readings based on the frequency involved. Since you seem to know what you're talking about, we volunteer you to look into this.
Of course then we'd need to understand the readings well enough to understand if or how a shim/shaving might be beneficial.
I wish I did have the right equipment to do the tests and then be able to compare the different sensors under the same conditions. Whats interesting to me, is the fact that the sensor is measuring the magnetic changes presented by each position of the cam. The physical position of the sensor could change the output of the sensor dramatically, thereby giving the CPU incorrect or weak signals.
Nick
Nick
The rougher idle would make sense if it's a weak or incorrect signal, but how does that play in to the traditional CPS failure issues. As I understand it, the CPS gives off a simple binary on/off signal based on the indentions in the cam gear. How does the magnetic sensor suddenlt start to miss a groove and cause a split second cought, or worse, a complete failure.
Magnets don't typically just instantaneously go bad, so I don't really understand the mode of failure with these things. With that said, would shimming the CPS (if it fixed the rougher idle) have any affect on the typical issues we usually associate with the CPS?
