key scratch
Old Oct 26, 2008 | 10:55 AM
ilo9's Avatar
ilo9
Exclamation key scratch
I have a key scratch on the passengers side of my King Ranch. I need touch up paint to fix it. is it readily available? I have a brown 2004 King ranch. Has anyone ever fixed a scratch that is not down to the primer but deep enough to feel with a finger nail?
Old Oct 26, 2008 | 11:57 AM
cartmanea's Avatar
cartmanea
Is it all the way through the clear coat? If not, try using a medium buffing compound and see how that does. Touch up paint will probably just make it look worse.
Old Oct 26, 2008 | 05:09 PM
the winemaker's Avatar
the winemaker
key scratch
there MAYBE afix.. I had some scratches on my white king ranch and a friend used a mixture of white tooth paste and baking soda ..mixed up good and rubbed the scratches out buf with dry cloth and then applied a coaxt of wax lo and behold scratches gone...you may want to try..........the wine maker
Old Oct 26, 2008 | 08:54 PM
dfooch's Avatar
dfooch
If you go the touchup paint route, go to the dealer and give them the VIN so they order to match the paint to your truck.
Old Oct 27, 2008 | 12:15 PM
ilo9's Avatar
ilo9
Update
Heard from a friend about Quixx scratch remover. bought at wally world, tried it on a small section of the scratch behind the cab in between the bed and the cab. it worked a little to remove where it wasnt too deep, only problem....it requires you to wetsand the truck....I am really scared to start sanding this great paint job. friend tells me to touch up the scratch and then use this stuff, without the wetsand step and the scratch will be gone. That is the route I think I am going to try next. BTW I tried this Quixx stuff on a scratch on the tailgate and it is gone with just using the two part system, no sanding...amazing...I have been looking at this little scratch for years and it is gone....15.00 at wally world.
tricker04
Apr 8, 2013 09:25 AM
flhr
2004 - 2008 F150
Nov 25, 2010 07:55 PM
Supercrewzin01
2009 - 2014 F150
Jan 30, 2009 09:53 PM
oscar_007
1997 - 2003 F150
15
Oct 12, 2006 09:16 PM
texasmelon
Appearance & Dress-Up
Jun 17, 2003 05:55 PM
