Front Leaf Springs?
Old Oct 26, 2008 | 02:40 AM
blue66tang95f150's Avatar
blue66tang95f150
Front Leaf Springs?
I have a 96 f250 4x4 7.3 with a 175k on the odo. My question regards the front leaf springs. Mine are pretty sagged and the tires actually sit slightly tilted in at the top. I would like to get some good factory ones, but i don't want to fork out the money. My question is if the gas powered leaf springs are the same as the powerstroke, and if the f350 springs are the same or not. If they are all the same. I was thinking of looking at a few wrecking yards around here and seeing if I could find some out of a 351 truck. That way most likely the springs arnt as sagged due to the less weight up front. What do you guys think?
Old Oct 26, 2008 | 09:21 AM
Jeff Dodson's Avatar
Jeff Dodson
From what I am told, the springs from the gas motor wont hold the weight of the deisel motor. I was going to do a swap with a buddy, the guy I traded trucks with but was told that the diesel would severly sag the gas springs. BTW the tires sitting like that is normal on the diesel engines because of the weight. My old 91 did the same thing. I had the WHOLE front end checked and the was nothing wrong. That is normal for the old diesels.
Old Oct 26, 2008 | 11:56 AM
blue66tang95f150
hmm, it sits pretty low up front and its a 4x4. I have keeping my eye out for other f250s and mine for sure sits lower than any of the ones i have noticed. Either way, I want to get the front up roughly the same height of the rear. Maybe I will swing by ford tomorrow and see if the springs are different betwee the gas and the diesel.
Old Oct 26, 2008 | 03:47 PM
ChancesDad's Avatar
ChancesDad
My '97 F-250 4x4 w/ Off Road Package has a 460 and the front leafs are bowed up, I only have 1" of travel between the leafs and the bump stop.
'97 F-250 HD XLT SuperCab 4x4 O/R 460 - 5 Spd
'96 34ft Fleetwood Bounder 460 - E4OD
'68 F-100 Custom Cab on '78 F-150 Ranger 4x4 Frame 390 FE - C6
Old Oct 26, 2008 | 04:53 PM
themoparkid's Avatar
themoparkid
i too only have about 1" of travel. i sometimeswonder if i do bottom out or not.
Old Oct 26, 2008 | 05:47 PM
bigtruckcpl's Avatar
bigtruckcpl
here is a site that sells factory springs and also lifts the new fronts cost I believe 231.00 plus tax and shipping I'm sure Custom Suspension
Old Oct 27, 2008 | 06:48 AM
Jeff Dodson
These trucks have the negative arch springs, this is normal, it is suppose to help with the handling of these trucks. The old way get rid of the negative arh springs is an after market kit (at 4"" )
Old Oct 27, 2008 | 01:35 PM
andym's Avatar
andym
I can guarantee that gas springs are way lighter than the diesel springs. That motor is a LOT heavier.
You can only return the truck to its stock height if you want to keep it aligned. If you raise the front of it you have to either install camber bushings or drop brackets to get it aligned again.
Old Oct 27, 2008 | 02:34 PM
blue66tang95f150
Yeah I just want to return it to stock height, maybe slightly higher just to match the rear a little better. I don't want an actual lift kit for bigger tires. Has anybody ever just took apart stock front springs and added one leaf to the front. Somebody emailed me and said they have some I can have. So I was thinking of taking his apart and using one leaf to add to mine.
Old Oct 27, 2008 | 06:33 PM
c_rossman's Avatar
c_rossman
Just go to the junk yard and get a set of used leaf's. Just add one leaf from the pack so you will have 3 leaf's instead of 2. This will bring it right up to where you want.
tlapham
Feb 3, 2017 09:07 AM
SuperDutyScaler
Apr 8, 2016 09:23 AM
TJDave
Feb 8, 2011 04:09 PM
jim042796
Apr 29, 2008 08:30 PM
V8 Andy
Nov 16, 2005 09:51 AM
