MAFS on 302
Old Oct 26, 2008 | 06:42 AM
ymeski56's Avatar
ymeski56
Der Postmeister
MAFS on 302
Did MAP go to MAF when the OBD1 went to OBD2 or are there any OBD1's
running around w/ MAF's also, especially 302's?
Old Oct 26, 2008 | 08:58 AM
Blurry94's Avatar
Blurry94
You'll find mass air applicaitons on many 94+ 5.0/F-150 that are EEC-4 OBD1.
Then there are the mass air conversion kits for the EEC-4 trucks.
Old Oct 27, 2008 | 03:01 PM
WTRBKT55's Avatar
WTRBKT55
Ford Racing MAF Conversion Kit FOR SALE
I've got a brand new Ford Racing MAF conversion kit for sale in the classifieds here if your really interested. Won't be cheap but it is the easiest way for get MAF for Ford MAP trucks.
Old Oct 27, 2008 | 05:49 PM
fiveofastback's Avatar
fiveofastback
What is the criteria for the MAF 5.0 truck what years and equipment. Mine is a 95 F150 4wd ext cab lb 5.0 with 5spd manual 170k miles
Old Oct 27, 2008 | 06:35 PM
WTRBKT55's Avatar
WTRBKT55
Response To Ak Kit Question
The Ford Racing kit M9000-T50/T51 is designed to be used with any 1987-1995 F150/F250 with a 5.0L engine using an AOD/C6 or manual transmission. The only difference is the computer an A3M for a manual trans application or I have a A9P for an automatic trans application. It really is an easy way to get Mass Air Flow capability in these older trucks and allows for any performance upgrade you may want to incorporate, like a bigger cam or performance heads. Thanks for asking and hope this helps.
