Sponsored by: Auxito
Rear Diff. size?
Old Oct 23, 2008 | 10:30 PM
NEsupercrew's Avatar
NEsupercrew
Rear Diff. size?
I have a 2001 F150 Super Crew. I am not sure what size the rear diff is, 8.8" or bigger. Here is the VIN if that helps 1FTRW08L61KE55641.
What diff. oil(brand) would be the best to put in it and how much(2.6qt or more)?
Thanks for the help.
Old Oct 23, 2008 | 10:33 PM
NEsupercrew
Sorry...could a site mod put this in the proper forum section. Thanks
Old Oct 23, 2008 | 10:43 PM
galaxie641's Avatar
galaxie641
If you have a 5.4L you have a 9.75 otherwise you have an 8.8.
They take 75w140, doesn't matter what brand find the cheapest. IIRC they take 3 pints but your owners manual will say for sure.
Old Oct 23, 2008 | 11:00 PM
NEsupercrew
Thank you. Yes I have the 5.4L. I did some searches on the site here and did find one thread that said to look at the tags attached with the cover bolts. So I just got back in from looking and it has the 9 75 on the tag located on the passenger side, which to my understanding would be the 9.75".
As far as the amount I believe the manual calls for 2.6qts for both the 8.8 and 9.75, is that correct? Do I need to add the friction modifier also?
Old Oct 23, 2008 | 11:31 PM
NEsupercrew
Ok, well I keep answering my own questions. Just to make sure though, on the door sticker....it says 'AXLE' and there is a 19 under that. That means I have a NON-LS diff. correct? Therefore no friction modifier.
Old Oct 24, 2008 | 08:12 PM
96f150's Avatar
96f150
You are correct. You have a 3.55 open diff, no modifier required. I'm suprised that youhave an open diff, I thought the Supercrew's mostly came with an LS diff. I think the 3.73 ratio wasn't available until 03. I wish I had the 3.73 for more off the line pull.
Rich
Old Oct 24, 2008 | 10:16 PM
NEsupercrew
Thank you. Has anyone used SuperTech gear oil from Walmart? It all comes from the same spot in the ground so why not...plus it's $5 a bottle cheaper.
Old Oct 25, 2008 | 08:52 AM
steve(ill)'s Avatar
steve(ill)
i have used the wal mart- good stuff. it is imortant to use the full synthetic. it will help with gear whine, run cooler, and is the new spec for FORD.
bluecobra
1997 - 2003 F150
Jul 1, 2014 03:50 PM
GSCPSD
13
Jun 12, 2012 06:28 PM
427ford
Feb 25, 2010 05:22 PM
wreedZ71
2004 - 2008 F150
Apr 19, 2009 11:07 AM
brandonsd
Feb 12, 2008 01:49 PM
