Sponsored by: Real Truck
? on types diff covers
Old Feb 11, 2008 | 11:31 AM
brandonsd's Avatar
brandonsd
I am trying to get diff covers for my front and rear diffs, but i am not sure what size or bolt or whatever they go by that i have. My truck is a 01 f250sd 4x4 v10, if anyone can help it will be appreciated.
Old Feb 11, 2008 | 12:07 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
If it's single-rear-wheel (SRW) you have a Sterling 10.5" in the rear, and a Dana 50 in front.
Old Feb 11, 2008 | 12:15 PM
dkf's Avatar
dkf
The new 08' SDs come with a cast finned aluminum Rear diff cover that will fit older trucks as well. An FTE sponsor sells them, I think they cost around $70. I'd like to put one on my 04'. Its a cheaper alternative to an aftermarket cover.
Old Feb 11, 2008 | 12:24 PM
lariatbob's Avatar
lariatbob
Any more detail on that sponsor that sells them?
They look great, and that's a great price!
I need to know!
Old Feb 11, 2008 | 12:57 PM
RickF350's Avatar
RickF350
^ http://www.dieselmanor.com/motorcraft/FD-3Z4033A.asp
Old Feb 11, 2008 | 01:18 PM
bbender85's Avatar
bbender85
and it's my understanding that a Dana 60 cover will fit the front, since you won't find many listed as 50. same housing, w/ D44'ish internals.
Old Feb 11, 2008 | 02:03 PM
Citypol86's Avatar
Citypol86
This is an option. Its much cheaper and will work the same as stock. If you want to throw more money at it you can, though.
Rear- http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=013
Front- http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=013
Later...
Brewster...
Old Feb 11, 2008 | 04:28 PM
brandonsd's Avatar
brandonsd
when i look at them to buy they go by like 12 bolt for rear, and all i find for front is dana 60 or dana 44 can anyone tell me which is the correct one for the front.
Old Feb 11, 2008 | 04:51 PM
krewat's Avatar
krewat
Good point.
I did a quick google for "diff cover sterling 10.5" and it indeed is a 12-bolt (although to me that's a Chevy term).
And there's plenty of Dana 50/60 covers too...
Old Feb 11, 2008 | 06:25 PM
Ponyboychris's Avatar
Ponyboychris
I second the rear diff cover from DieselManor. Comes with the correct length bolts. The rear diff oil cost more than the cover...
Old Feb 11, 2008 | 06:57 PM
Gage2502's Avatar
Gage2502
What brand of read diff oil are you guys useing?
I used Red Line on my 1988 Cougar XR7, is it ok to use Red Line in my Super Duty?
Thanks ~Gage~
Old Feb 11, 2008 | 11:19 PM
racincowboy's Avatar
racincowboy
Stay away from chrome covers they do not disapate heat very well. I went with finned aluminum that exhanges heat very well and a lil extra oil in there doesnt hurt either. Redline oil should be just fine as long as you make sure you have an open rear end and make sure you dont need to put in the additive for a limited slip.
Old Feb 12, 2008 | 02:15 AM
thedaddycat's Avatar
thedaddycat
If you want the cover for looks then the new ones are fine. If you want function then I would suggest looking at Mag-Hytec and others. I have M-H diff covers and tranny pan. They have higher fluid capacity and heat transfer ability, magnetic drain plugs and dipsticks, O ring seals, are tapped for temp probes, come with SS Allen head bolts and Allen wrenches to install them. Yes they do cost more, but I've never seen my tranny temp over 145*F with it.
Old Feb 12, 2008 | 06:27 AM
slowmans's Avatar
slowmans
I used royal purple for mine! it has the additive in it for the limited slip.
Old Feb 12, 2008 | 06:33 AM
ben8892002's Avatar
ben8892002
i have the new ford cover on my sd and i love it. i did'nt want the mag hytec because of a the price and b i don't see why you need the extra capacity. i tow constantly all summer long. i never had a problem with the steel cover but the finned aluminum cover definatley cools substantially better for alot less than the mag hytec.
