tranny ?
Old Jul 18, 2002 | 11:09 AM
ions664x4's Avatar
ions664x4
tranny ?
I have rebuilt my c-6 in my truck.It worked fine until I adjusted the modulator for early shifting problems.The trans still shifts too early for my taste so I will put in a shift kit.The problem is when I put the truck in reverse it feels like it goes into gear,then it slips out of gear.If I give the engine a quick rev it will slam into gear.Is this a problem with the valve body or arethere problems with the reverse piston/clutches.I readjusted the mod,but have not seen any change.
Old Jul 18, 2002 | 07:28 PM
Brian460's Avatar
Brian460
tranny ?
I don't think that the modulator is your problem in reverse, as it is to use the engine vac. to determine when to upshift to 2 and 3. It may sound stupid but you need to make sure it has the proper amount of fluid in it. Sounds like there is some internal problems.
Brian
Old Jul 18, 2002 | 09:31 PM
Brian460's Avatar
Brian460
tranny ?
William525
Jun 13, 2013 07:47 AM
JHowey1989
Jul 22, 2010 12:46 AM
JHowey1989
16
Jul 10, 2010 12:16 PM
zer0321
Sep 12, 2007 12:54 AM
