cracked dash ?
Old Oct 20, 2008 | 10:27 PM
indebt's Avatar
indebt
cracked dash ?
need some ideas on how to fix my dash......
Old Oct 20, 2008 | 10:40 PM
87 F-150 I6's Avatar
87 F-150 I6
Looks like you need a new dash, you could get one of a junk yard truck or a new one.
Th!nk Parts Guy
They should have what you need but if you don't find it call, he can get anything ford.
Old Oct 20, 2008 | 10:42 PM
87 F-150 I6
Here is a more pierce parts list from him.
Th!nk Parts Guy
Old Oct 20, 2008 | 10:50 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Odds are, if you fill the crack, sand it down and paint it. It will crack again, temperature variation alone will do it! BUT.....you can pull the panel out, put some two-part epoxy or liquid nails on the back side of the crack to strengthen the panel from behind to prevent recracking. Fill the crack, sand, paint and it should hold up. In theory.
60RatRod's Avatar
60RatRod
There is a place in CA called JUSTDASHES that specialize in that stuff. Try a google search and see what comes up. its been years since I used them.
Old Oct 20, 2008 | 10:52 PM
bdrummonds's Avatar
bdrummonds
pull dash bezel,then from the back side use some 5 minute plastic 2 part Epoxy, after it sets (5 mins) you may have to sand a little seepage from the front, have a can of interior spray paint handy, and touch up any other blemishes.
total cost $4 for the epoxy, and your time.
EDIT: Chris beat me to it, but I have done it, and mine is still holding.
Old Oct 20, 2008 | 11:00 PM
indebt's Avatar
indebt
cool thanks for the ideas guys, will do. I was just gonna jb-weld the back, but I will try the epoxy and then jb-weld the back.
Old Oct 21, 2008 | 12:06 AM
87 F-150 I6
didn't even think about epoxy or liquid nails, much cheaper, now why did'nt I think of that?
Old Oct 21, 2008 | 12:24 AM
indebt's Avatar
indebt
thats we were all here, to bounce ideas all around!
Old Oct 21, 2008 | 10:43 AM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
yea a new dash is just not cost effective for this issue.
Ed
Old Oct 21, 2008 | 11:13 AM
tinker934's Avatar
tinker934
your dash
WAIT A MINUTE im doing the some thing right now just in a different
spot on the dash. did the jb weld and it recracked again (idea)i ended
up useing some a pieces of that matting for fiberglassing (that white cloth looking stuff u can get a kragens,wallyworld,or just ask a body shop you just need a small piece) then sand down the spot then JB,CLOTH JB then youl be golden oooo use the felxable primer if you go the route . im useing 320,220 fro my sand paper
Old Oct 21, 2008 | 11:23 AM
indebt's Avatar
indebt
thanks for the tip...
indebt
2004 - 2008 F150
13
May 22, 2011 01:40 PM
indebt
Jan 14, 2011 09:34 PM
indebt
18
Nov 14, 2008 08:55 AM
indebt
13
Nov 13, 2008 08:07 AM
indebt
Sep 2, 2008 09:02 PM
