Sponsored by: Real Truck
Help no blinkers
Old Oct 19, 2008 | 04:53 PM
Budman1962's Avatar
Budman1962
Help no blinkers
I have a 2000 f250 and the turn signals stopped working. The emergency flashers still work fine. I took the multi-function switch apart and cleaned all the green goo out and put dielectric grease on the contacts But still not working. I think if the relay wasn't working the emergency flashers would not work. I took it apart again and lightly sanded the contacts but it didn't help. Any help would be great.
Budman
Old Oct 20, 2008 | 02:15 AM
Mike-11's Avatar
Mike-11
You might want to check the fuse box and see if the fuse is blown out.
Old Oct 20, 2008 | 10:34 AM
riggz's Avatar
riggz
Also make sure you aren't out of blinker fluid.
sorry couldnt resist! :P did you check for voltage at the contacts?
Old Oct 20, 2008 | 04:12 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Budman
Emergency flasher uses a completely different circuit - namely, the brake lights.
Dielectric grease is NOT CONDUCTIVE
Check all the fuses, even the flasher itself. Could be the flasher if both sides are not working.
Old Oct 20, 2008 | 05:18 PM
Budman1962's Avatar
Budman1962
The fuse is good. I wonder if the relay can be bad and still have the emergency flashers work.
Old Oct 20, 2008 | 06:04 PM
Budman1962's Avatar
Budman1962
All this messing around with the multi-function switch and it turned out to be the flasher. I don't know why the flasher would work for the emergency flashers but not for the turn signals. All is good now. Thanks for the help!
Budman
PS, I always use synthetic blinker fluid!!!
Old Oct 20, 2008 | 08:58 PM
krewat's Avatar
krewat
Because there are two flashers, one for the directionals, one for the emergency flashers?
Old Oct 20, 2008 | 10:27 PM
bgalaxy67's Avatar
bgalaxy67
I have the same issue but mine is a dead short somewhere. Sometimes it grounds out the circuit, other times it doesn't. But every time it blows the fuse. I'm sure it will be a fun one to find
Old Oct 20, 2008 | 10:44 PM
Budman1962's Avatar
Budman1962
Dielectric grease is not conductive? I thought that was its purpose.
Old Oct 21, 2008 | 09:07 AM
krewat's Avatar
krewat
Then why use it on spark plug boots?
Seriously, it's NOT conductive.
Old Oct 21, 2008 | 01:29 PM
Budman1962's Avatar
Budman1962
Good point. Thanks for the info. Always something to learn on FTE.
Budman
boatordie
Sep 30, 2016 07:44 PM
chipper
1997 - 2003 F150
Sep 12, 2016 06:12 PM
skd91
Large Truck
Oct 31, 2015 09:34 PM
Holtian
Dec 14, 2009 05:25 PM
JimUT
Feb 19, 2002 06:51 AM
