Offroad & 4x4
leveling kit
Old Nov 17, 2000 | 02:37 PM
visegrip's Avatar
visegrip
leveling kit
has anyone out there ever used a leveling kit to raise the front end of there truck so it sits level with the back of the truck ?
Old Nov 17, 2000 | 07:53 PM
traildawg's Avatar
traildawg
leveling kit
Haven't used one, but seriously considered them prior to just going with a full lift kit. Basically the leveling kit will consist of longer springs for the front and possibly shocks.
TrailDawg
Old Nov 17, 2000 | 11:10 PM
windsor's Avatar
windsor
leveling kit
I installed taller front coil springs on my 95 f150 4x4 about a year ago and it makes a big differance in appearance etc.. You have to buy longer shocks,I bought a set for the rear also.I also replaced my radius arm bushings while I had the front end tore down.In case your wondering,I put 32/11.50/15 BFG ALL Terrain T/A on,with minor trimming to plastic valance.Good Luck Windsor
Old Nov 18, 2000 | 01:55 AM
roadrage2's Avatar
roadrage2
leveling kit
I installed Skyjacker front leveling coils on my '95 bronco. They are great, ride good and didn't have to replace shocks. A alignment will need to be done with offset camber/caster bushings. I clear 33x9.5 BFG MT's with no other mods.
Old Nov 22, 2000 | 10:27 AM
Eddie's Avatar
Eddie
leveling kit
Thanx for the tips about tire sizing. I think my next step will be 33X12.50-15s, up from 31x10.50-15s.
Eddie
Old Dec 11, 2000 | 01:31 AM
halvey's Avatar
halvey
leveling kit
[font size="1" color="#FF0000"]LAST EDITED ON 11-Dec-00 AT 02:33 AM (EST)[/font][p]When I bought my truck, it had a 2-1/2"(I think) Trailmaster suspension lift in it.(95 F-150 shortbed) I just took the lift blocks out of the rear end, and now it sits perfectly level. 33x12.50's Tom
Old Dec 21, 2000 | 12:48 AM
95xltmud's Avatar
95xltmud
leveling kit
Where did you guys purchase your leveling coils from? How much do they cost? did you replace all 4 shocks up front when you swapped the springs? I am planning on installing a 3" body lift on my truck but before I do it I want to level out the truck. With the front end lower it really gives an illusion that the rear tires are much smaller because of the extra clearance in the rear. Leveling the truck will make it look tons better, but I have been unable to locate a leveling kit from anywhere.
Old Dec 23, 2000 | 12:49 PM
proeliator's Avatar
proeliator
leveling kit
bigc1301
All Things Towing
30
Oct 11, 2017 06:44 AM
spike1382001
2009 - 2014 F150
Mar 28, 2014 02:22 PM
mean1500
Sep 15, 2013 12:29 AM
Michael Pace
Jul 7, 2013 08:47 PM
maxnoodle
Mar 17, 2008 12:02 PM
