Ow do I know if I have the eps on my truck I am about to install a leveling kit and it says to disconnect it when doing the leveling kit. another thing is where is it located at if I do have it?
+ one to Tim's post. I have put a leveling kit then took that off and put bilstien shocks on. All I did was disconnect the negative side on the battery and I have not had any problems with my EPS.
fwiw
I added a 1" lift and did not know to diable the EPS, fortunately I don't see any adverse effects. Had I broken it, what would the ill effects look like?
