What causes Coking?
Old Oct 9, 2008 | 08:26 PM
Benchwrench's Avatar
Benchwrench
What causes Coking?
Vehicle maintenance, turbo, oil, fuel, air induction, all have an effect on coking.
EGR valve replacement/ cleaning is related to the occurrence of coking , the original causes should be corrected or the coking will reoccur.
There are TSB's related to coking and other diesel operating systems that could contribute to coking of the intake system, EGR valve specifically.
If the root cause of coking is related to one or a combination of the above, it would be nice to understand how to address the coking build up in the intake.
What are some of the TSB's that are related to the root cause of this effect, and how can we reduce this nuisance?
Old Oct 9, 2008 | 08:44 PM
adambomb's Avatar
adambomb
i would like to know too.
i always thought it was caused by making short trips, idle for a long time, and shutting off your truck when the EGT's were high leaving hot oil sitting in your turbo.
*bump*
Old Oct 9, 2008 | 08:50 PM
bismic's Avatar
bismic
TSB on coking:
TSB 08-2-7
Coking deposits are generally un-combusted or incompletely combusted hydrocarbons and can form on system components such as the EGR valve, EGR cooler, EBP Sensor, EBP tube, intake manifold, turbo charger, catalytic converter and EGR throttle plate. Deposit sample analysis from warranty return parts confirms the source as engine oil or diesel fuel. Visual inspection CAN NOT link the sources of coking deposits as either from engine oil or diesel fuel. Coking deposits can be identified as shiny black grease like sludge, hard flat black solid mass, or thin light brown sticky layer.
Un-combusted deposits can be linked to delayed combustion events. Delayed combustion events can be a function of hard to ignite elements (poor quality fuel, excessive fuel, engine oil or excessive exhaust gas recirculation) in the combustion chamber or a delayed injection event (calibration, wire chafe, injector mechanical issue). Un-combusted fuel is usually evident as fuel scented white exhaust smoke. Un-combusted fuel may create coking which impairs system functionality eventually leading to black exhaust smoke/poorly combusted fuel.
Also (might be helpful):
Symptom Chart Index
http://www.motorcraftservice.com/ren...e=EN&viewer=IE
Old Oct 10, 2008 | 05:59 AM
bismic's Avatar
bismic
Here is another TSB on Turbo coking:
TSB 08-16-13
Old Oct 10, 2008 | 11:12 AM
Benchwrench
What I get out of this whole coking problem is that it is directly induced via the egr cooler/ valve circuit. Is this correct?
So, if the "y" portion of the exhaust up-pipe was removed, then there is no way for these deposits to enter the intake circuit, right? Now this won't eliminate fouling in the turbo but the temperatures of hot exhaust gasses hopefully will keep coking in the turbo at bay.
So, will the elimination of the egr cooler circuit by physically disconnecting the exhaust flow at this connection have a significant effect on eliminating the coking build up?
I don't know of any other remedy. Maybe someone out their has another viewpoint.
SkySkiJason
37
Nov 19, 2025 12:43 PM
moltman
2015 - 2020 F150
21
May 26, 2017 01:44 PM
LoriM
Aug 2, 2015 03:15 PM
makuloco2000
2009 - 2014 F150
13
May 30, 2014 03:36 PM
6LPSD
Jan 12, 2009 04:43 PM
