Part Identification
Old Oct 9, 2008 | 08:07 AM
03_PSD's Avatar
03_PSD
Part Identification
Hey, I don't want to freeze this winter again, so I need some help determening the right part to fix. I've gotten some help with previous threads on this subject but heater still no worky.
The problem I'm having is the truck's heater don't put any heat out what so ever. I've replaced the a/c heater controls on the dash, still no worky. I'm pretty sure I've narrowed the bad part to the door blend thingy. Now my question now, is it called the "Actuator". This is where I'm looking for the parts Th!nk Parts Guy
Thanks!
Old Oct 9, 2008 | 10:27 AM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
3C3Z19E616BA is the blend door actuator. here is a picture
Ed
Old Oct 9, 2008 | 10:33 AM
03_PSD's Avatar
03_PSD
Thanks Ed, PM sent
Old Oct 9, 2008 | 10:38 AM
bdrummonds's Avatar
bdrummonds
And you are positive that a heater core shut off valve has not been installed, and is not stuck in the closed position, right?
I seem to remeber that some 02 and 03 thrucks had these from the factory, and it is also the cold air mod I have done to my truck.
Old Oct 9, 2008 | 10:43 AM
03_PSD's Avatar
03_PSD
I haven't done that mod Brandon, but thanks for the heads up. I'll check that right now.
Old Oct 9, 2008 | 10:47 AM
03_PSD's Avatar
03_PSD
ok, well looked at the heater lines Brandon and it does have some sort of valve installed from factory, assuming. Whats an easy way to check if its shut or broken?
Old Oct 9, 2008 | 02:36 PM
03_PSD's Avatar
03_PSD
bumpity bump
Old Oct 9, 2008 | 02:59 PM
PaysonPSD's Avatar
PaysonPSD
If the control valve is opening the hose going to it and the one leaving toward the heater core should both feel like they are at the same temp. If the the inlet hose feels warmer then the outlet hose the valve is closed. It is vacumm operated so make sure the vacumm line is attached.
Old Oct 9, 2008 | 03:10 PM
03_PSD's Avatar
03_PSD
Thanks Robin, will check that out.
Old Oct 9, 2008 | 04:07 PM
bdrummonds's Avatar
bdrummonds
Yep, hoses will be hot before the valve, and cool behind the vavle(near the firewall)
On most, default position is open, but if you have been running MAX A/C all summer then the vavle may be stuck in the closed position.
Old Oct 9, 2008 | 06:33 PM
maevans's Avatar
maevans
Great advice Brandon..
Old Oct 9, 2008 | 06:37 PM
Kwikkordead's Avatar
Kwikkordead
You could also simply remove it from the hose and put in a bridge pipe.
That would give you full flow no matter what.
Old Oct 10, 2008 | 08:45 AM
03_PSD's Avatar
03_PSD
thanks for the help, i'll post what i find out later today
bulletpruf
Nov 25, 2012 05:08 PM
Ricache
Aug 28, 2010 12:45 AM
frankbank
Sep 6, 2009 11:43 AM
mustangpete1013
Jul 6, 2005 06:21 AM
truchafuego
Mar 21, 2005 08:42 AM
