freezing optima's
Old Oct 8, 2008 | 09:49 PM
dodmort's Avatar
dodmort
freezing optima's
ok
will your optima battery freeze if it is left out in below 32 degree weather and not used for 6 months...
it will have a on board maintainer going..
Old Oct 9, 2008 | 08:28 AM
ReAX's Avatar
ReAX
With a trickle charge, it should be fine. As I understand it, the optima uses an electrolytic gel and not the normal water/sulfuric acid mix. Because of the lower water content I suspect the freezing the temp has lowered.
Old Oct 10, 2008 | 08:02 AM
dodmort's Avatar
dodmort
thanks
think i will try it out this winter and see if it stays charged and ready
Roasted7
Aug 30, 2012 03:15 PM
chappys4life
Dec 13, 2011 02:29 PM
teamptg
Jan 17, 2005 09:30 PM
landryd
1983 - 2012 Ranger & B-Series
Jun 17, 2004 11:16 AM
