wiper problem 88 f150
Old Oct 7, 2008 | 03:41 PM
05chop's Avatar
05chop
I did the search here not sure if i need this governor.This is my problem.Works on high only if i unplug the black plug going to the center of the wiper motor.If i plug the black plug in it slows down till it stops.I checked volts to the motor and its reads battery volts.Then i replaced the wiper motor still have this only works on high setting but real slow then unplug black plug runs fine in high.Does this sound like i need the expensive governor that unplugs from the wiper switch to the black box to the main wire harness?
Old Oct 7, 2008 | 09:48 PM
F150xlt's Avatar
F150xlt
Here's the schematic for the interval wiper.
When in Hi mode, 12 volts goes direct to the wiper motor. (Bypasses the delay module).
The majority of the problems turn out to be cold solder joints on the delay wiper module circuit board which is enclosed in a black plastic housing.
On the circuit board is a large diode mounted on a heat sink where the solder cracks which can cause only Hi speed to work. Another problem I've seen was a bad solder joint around one of the electrolytic caps which must of been for the delay timing circuit because the delay interval sometimes didn't work.
If you follow the wiring harness from the wiper switch it leads to the delay wiper module which is bolted by a small bolt to the bottom of the dash frame very close to the emergency brake release mechanism.
Old Oct 7, 2008 | 10:41 PM
05chop's Avatar
05chop
Well thanks for the picture diagram.This is what i did today ,removed the black governor box,removed the plastic cover.I checked for correct solder connection then decided to inspect the clear plastic covered electronic switch.i carefully removed the clear plastic cover over this switch then i sanded down both sides of the switch points.Plugged it all back into the switch and main harness and so far its working.
Rogue_Wulff
27
Dec 18, 2016 08:59 AM
hanketsu
Mar 19, 2016 04:43 PM
Bundter
Jun 30, 2013 10:49 AM
david73796
Jul 3, 2004 02:16 PM
Bear 45/70
Electrical Systems/Wiring
May 6, 2004 02:42 PM
