Jumpy throttle
Old Oct 7, 2008 | 07:31 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i still say its the ivs/tps relationship that is your issue, i think the tp voltage is over .85 before the ivs trips off.
Old Oct 7, 2008 | 07:40 PM
RubberDuck's Avatar
RubberDuck
So what should I be seeing out of both. I'm with you, I think they are outta whack too. But I also noticed today that it's jumpy in and out of the throttle before I let off the pedal. It may be too much ICP.
Old Oct 7, 2008 | 07:46 PM
MADVAN's Avatar
MADVAN
Might have something to do with the edge fliter IPR.
It could slow the oil to the drain.
IICR a tps of 1.5 before IVs sets will cel.
I was running .8v for idle TPS. Have good luck now
running .63v. Idles like a timex.
Bill
Old Oct 7, 2008 | 07:53 PM
RubberDuck's Avatar
RubberDuck
How did you make that adjustment Bill?
Old Oct 7, 2008 | 07:59 PM
MADVAN's Avatar
MADVAN
Same as the pedal mod. Just adjusted it in idle mode.
Then grind for the WOT voltage you want.
IICR i set it 3.7 for WOT. Never could get 4v out of the TPS.
Bill
Old Oct 7, 2008 | 10:58 PM
barebackjake's Avatar
barebackjake
have you tried it with the chip out yet?
Old Oct 7, 2008 | 11:19 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Here's what you do, take my pedal off your truck. Take the TPS off my pedal and install the new TPS, then promptly hand it to me. Take the TPS that has "missed" a few times and put it on your pedal, then re-install. LOL There is NO test, retest with the new parts, unless you are buying more. Electronic parts are not refundable. I don't want a TPS that your truck has "Infected"! LOL
thanks for saying my truck is a fungus on wheels man. LoL. the only thing it infects is the ozone that the black smoke comes in contact with. LoL.
Now, do i have to wind up the tps or just stick it on there? i'm nervous dealing with the dang tps now that i already messed up one of them. LoL
Old Oct 7, 2008 | 11:50 PM
RubberDuck's Avatar
RubberDuck
Just put it on there. Why don't you bring it to the shop Sat. night and we'll deal with it. I'm probably gonna do Heath's VP44. So tell Matt too.
Old Oct 7, 2008 | 11:57 PM
strokin'_tatsch
alright i will tell him for sure since he just loves those little dodges soooo much. LOL. if i can get the tps i will bring it, but it didn't look promising from the guy i talked to at ford today.. he said 70 bucks for a tps, but he thinks i might have to get the complete assymbly?!?!?! wtf? LoL
Old Oct 8, 2008 | 12:48 AM
RubberDuck's Avatar
RubberDuck
Talk to Rex, and tell him Cody from Death Row Diesel sent you, that should help some.
Old Oct 8, 2008 | 05:57 AM
tjbeggs's Avatar
tjbeggs
Yep you gotta get the whole assembly unless something has changed in the last few months.
Old Oct 8, 2008 | 08:20 AM
Action4478's Avatar
Action4478
Jake, I've been watching my gauge and it doesn't seem to jump up when it happens, nor does it drop like a rock. But it is an electrical gauge. I've yet to monitor it on the scan gauge, but I'll definatly look at it when I get the chance. Also, I'm running the IPR from the 95 with the edge filter on this modified 17*. I swapped it to see if it changed the long crank to start. I need to put my 02 IPR back in as well.
So are you running 2 edge filters ?..
Is there one upstream in the pump?....
Like Bill said ,,may be restricting the drain...
Old Oct 8, 2008 | 04:04 PM
  #28
MADVAN's Avatar
MADVAN
I would think so Rick. As you know it was moved off
of the IPR and into the pump. Its a restriction. It keeps
the oil cleaned going to the IPR. With one in the pump
and one on the IPR it has a higher restriction of oil flow to
the drain. It will be harder for it to bleed off oil pressure.
The 17* will push more oil than the 15*. Duck states its a
modded 17*. A WAG on "modded" means even more oil.
You might see it in a scan if its the issue.
The ICP will be high with a low IPR duty. 0% is a wide open drain.
Bill
Old Oct 8, 2008 | 11:15 PM
  #29
c00nhunterjoe
i cant recall what my max tp is, but i know its over 4.0, i think its 4.3X. i have the ngs so i will get the readings on mine in the morning before work. also, if i recall your ipr at idle should be roughly 11-12% on hot oil.
to do my pedal mod i just cut the pedal stop out and replaced it with a peice of 1/4 inch diameter all thread, that made the max almost perfect and i removed the metal sleeves from the tps and got my fine tuning adjustments from there. it worked out great and i could really feel a difference in wot feel
