Next mod?
Old Oct 5, 2008 | 09:49 PM
sbxworship's Avatar
sbxworship
Next mod?
I'm thinking about selling my camper shell to get some money to put toward my next mod. I'd appreciate some input from the gurus about which direction to go first. Obviously, funds aren't plentiful, or I'd keep the shell for trips and such. I'm considering (in no particular order):
Stacks (6" mitres)
TW tunes
Gauges (pyro, trans, boost)
DIY stage 1's
I'd really like to hear what you guys think, and why. I'm thinking I should probably get the gauges first, for the sake of my trucks health, but I'd much rather get something a little more awesome, like the stacks, tunes, or sticks. I'm also concerned that with TW or stage 1's, I'll need to upgrade my HPOP (if not more) to keep up. Also, with my bullydog, I can't turn my chip all the way up, or the truck bogs down. Also does this in 2nd pos. at about 3/4 throttle, but clears up if I get into it harder or back off a bit. Would TW tunes fix this, or is there probably another issue? Thanks a ton, guys!
Old Oct 5, 2008 | 11:38 PM
c00nhunterjoe's Avatar
c00nhunterjoe
the issue sounds oil or fuel related, we will need more info to figure it out, i havent looked at your other post to see if you addressed my questions on it so i will go re-read it before i start on this one as well.
how much money are you spending at one time? that will depend on what to buy and when.
Old Oct 6, 2008 | 01:49 PM
sbxworship's Avatar
sbxworship
Regarding the crappification, I've checked fuel pressure, hpop level, changed my oil (crankcase), removed/replaced 10k mod, replaced ICP (had a new spare on my other truck). It acts worse with the chip set higher, or the ICP resistance higher (14.7-22k). Also got much worse with FPR shim.
If there's any other info that would help more, just ask and I'll do my best. The truck has done this since I bought it about a year ago. the guy I bought it from always ran it with the bullydog in 2nd position. I'm wondering if maybe he didn't install it quite right... Lately, it tends to chug & shudder every now and then when I'm at lower rpm (1.2-1.6k). I don't know if that's related to the bogging down or not, but it definitely isn't right...
As for the money, it depends on how much I can get for the shell. I'm going to try craigslist, unless someone here is interested first. I might be able to put some more with it, but not much...
Old Oct 6, 2008 | 05:12 PM
c00nhunterjoe
i see you are running waste veggie oil. how does it run on diesel? the veggie can clog stuff up if its not strained enough
Old Oct 6, 2008 | 08:46 PM
sbxworship's Avatar
sbxworship
no different... I've cleaned the FPR and screen, too. I've run a couple tanks of diesel lately due to lack of oil supply, and it was just the same as biodiesel and WVO. I've tried seafoam (usually fill the bowl with it when I change my filter, which is pretty frequently), and dieselkleen. no change, but it made me feel a little better...
I noticed today that my valve cover harnesses are scorched pretty bad. would that cause these problems by not getting a good connection to the injector? it's completely disintegrated a couple pins... I plan to fix it, regardless. Time to do glow plugs, too...
Old Oct 7, 2008 | 10:50 PM
250ssd's Avatar
250ssd
Do an exhaust then guages. The tuner can come down the road and you will be ready for it.
ARW
13
Jan 1, 2015 09:21 PM
JCart
Dec 21, 2013 08:08 AM
KonaGrown
17
Aug 31, 2011 10:46 PM
phillips91
Mar 3, 2009 03:00 PM
79_250RangerLariat
17
Jun 28, 2008 09:46 PM
