Another TW question
Old Jun 22, 2008 | 06:30 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Another TW question
Well I helped a friend of mine move his girlfriend yesterday. I used my 97 5spd 3.55's (mods in sig) and steel horse trailer, he used his 05 6.0 auto 3.73's (cat back 4" straight pipe) and a borrowed alumiumn toy hauler. So off the start I was at a disadvantage with less hp and a much heavier trailer. It was about 150 mi round trip, I got better fuel mileage 15.8 vs his 11. Didn't have any problem keeping up with him, some of the long grades he was pulling away.
Got me thinking more and more about PMS I've gotta get gauges first, been looking at Summit today. But for you guys pulling which settings do you use the most? Best place to order? With fuel at 4.76 I'd like to keep my higher mileage towing... Thanks!
Old Jun 22, 2008 | 06:58 PM
foxracing0934's Avatar
foxracing0934
I dont know about the settings for TW, cuz i have a DP, but for the gauges itpdiesel.com has auto meters and dipricols for a pretty good price.
Old Jun 22, 2008 | 10:10 PM
GEugeneS's Avatar
GEugeneS
I don't believe the 6.0 is known for its good mileage (EGR and smog devices). It does spool up a lot faster, but over the long haul I trust more cubes for pulling.
Old Jun 23, 2008 | 09:18 AM
Neal 97 250's Avatar
Neal 97 250
Try hewitt industries for gauges. You have to call them and ask for Bruce Dankmeyer. TW has 2 tow settings. I use them for my 5er.
Old Jun 23, 2008 | 01:54 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Not to hijacke the post but how are they working?, any difference between 60 vs 80 hp?, what about the EGTs.?
thanks.
Old Jun 23, 2008 | 02:25 PM
Neal 97 250
He is somehow able to keep my egt's in check. Atleast before I did the II's. Not sure now.
I also haven't used the light tow and am considering getting rid of it.
Old Jun 23, 2008 | 03:03 PM
79_250RangerLariat
Thanks for the input. Where did you guys order your TW from? Not sure which positions to go with, thinking stock, tow, and smoke. Neal, did you have Tony burn the two tow settings? I only see one tow setting advertised. Maybe I'm not looking at the right one..
Old Jun 23, 2008 | 03:31 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
As I know Neal has the TW burned for two tow settings (60 and 80 HP IIRC), and he also askedTony to burn the chip for 2Stages before he put them and it worked fine with the stock injectors, am I right Neal?.
Old Jun 24, 2008 | 06:22 AM
Neal 97 250
That is correct guys. I knew I was getting stage II 's in the future so I had him do the burn ahead of time. The only problem I had with it is in the extreme setting I could feel a slight miss on hard acceleration. The injectors were running out of fuel. When I put in the II's that all cleared up.
Yes I have both tow settings but if I would do it again I wouldn't get bot settings, just the one I use most of the time. I would probably add another HP setting.
Don't get the smoke get a HP setting. I think he has a 70 HP setting for stock sticks. It runs really good and makes a little smoke.
Old Jun 24, 2008 | 07:25 PM
79_250RangerLariat
Neal have you towed with the extreme setting or is it just for fun
Old Jun 25, 2008 | 10:42 AM
Neal 97 250
I just use it for fun. When I tow, I tow heavy so I can't really play when towing. I use the work (tow) settings then.
Old Jun 25, 2008 | 02:26 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Neal have you towed heavy with the Stage 2's yet? How are your EGT's? (slow rise, do they still max out, how much of a pull before you have to back out of it, weight your towing, etc.) As much info as you can give will be helpful and if you haven't towed heavy yet let me know when you do tow.
Old Jun 25, 2008 | 03:05 PM
Neal 97 250
I haven't towed with the II's yet but I hope I can get the cooler installed before I do. I usually tow between 13,000 and 15,000 when I pull the camper.
I will let you know when I do. Have you done much towing with your II's?
Old Jun 25, 2008 | 04:19 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Quite a bit, 14,700# loader/backhoe & 3,200# trailer plus same trailer & 14 round bales (never weighed) plus same trailer & several differnet tractors weighing between 8,000 to 12,000#. I don't have a chip yet (hope to soon) or intercooler (have all of the parts except pipes & boots & time to put it in) and I have to watch the EGT's close on long hills because they will climb fast.
Old Jun 25, 2008 | 07:43 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I think that with the chip the EGT´s will be no problem any more? and better with the IC. Also let us know when you get the chip in. ok?
