Tranny problem... HELP!
Old Oct 1, 2008 | 05:18 PM
f-150 on 22's's Avatar
f-150 on 22's
I have a problem with my 2006 F150 4X4. I have had an intermitant problem (about a dozen times now) where after driving and I come to a complete or partial stop - during acceleration, I get a very loud noise - almost a grinding or draging sound from the transmission - sounds like maybe even a slipping sound. It's so loud that I have to pull off to the side of the road and then it stops - sometimes a loud clunk sound occurs. If I coast and put it in neutral it goes away.. any ideas??
Old Oct 1, 2008 | 07:03 PM
f-150 on 22's
Ok, so I went and got a new filter and gasket, and after I dropped the pan, METAL everywhere in my pan, the magnet is full of flakes, little chunks all over the pan.. Now I gotta get it towed to a good tranny place in Tallahassee... Anyone know a place?
Old Oct 1, 2008 | 07:12 PM
xjcamaro89's Avatar
xjcamaro89
Is it still under warranty?
Old Oct 1, 2008 | 07:14 PM
f-150 on 22's
No, I think I'm going to cry
Old Oct 1, 2008 | 07:52 PM
f-150 on 22's
So, if I am correct, the torque converter is not removable and replaceable?
Old Oct 1, 2008 | 08:45 PM
Timbo522's Avatar
Timbo522
I am having the same problem with my 05 4x4. Ford dealer had no idea what it was without tearing into it. You think it is the torque converter then?? Thanks.
Old Oct 1, 2008 | 09:18 PM
f-150 on 22's
Edge programmer picked up 2 codes... Anyone got any ideas? PO962 AND PO748
Old Oct 1, 2008 | 09:36 PM
shorebird's Avatar
shorebird
From Diagnostic Trouble Codes (DTC)
Definition of Diagnostic Trouble Code P0962
This Definition of P0962 is Applied to All Manufacturers Powertrain: Pressure Control Solenoid “A” Control Circuit Low
Definition of Diagnostic Trouble Code P0748
This Definition of P0748 is Applied to All Manufacturers Powertrain: Pressure Control Solenoid “A” Electrical
Old Oct 1, 2008 | 09:46 PM
ggwash21's Avatar
ggwash21
I had the same issue, i just got my truck back from the dealer and $4375 is what the total bill would have been if i didnt have a warranty.. I had ton of shavings in the pan. I had worn out clutch packings and a few other things. My truck would SLAM going into 2nd and 3rd gear every so often, and down shift hard as if i was down shifting it manually.
Sorry it is happening to you... its not fun thats for sure..
Old Oct 3, 2008 | 12:27 PM
f-150 on 22's
So, after taking it to a shop up here and having them fix the truck......the whole planetary gear set was shot..... $1,800 later.
Old Oct 3, 2008 | 01:23 PM
ggwash21's Avatar
ggwash21
Now get FORD ESP on that bad ride./...
Kregj
Sep 3, 2014 11:39 PM
brownsklan
2004 - 2008 F150
Jul 26, 2012 01:21 PM
99FORD EXPY.
2004 - 2008 F150
Aug 4, 2011 03:31 PM
F4L956
3.8 & 4.2L V6
Jun 6, 2007 05:33 PM
walkerrim
Aug 24, 2004 07:32 PM
