Excursion Super Duty
Old Oct 8, 2008 | 03:02 PM
  #46
1's Avatar
Originally Posted by Ace!
Also, anyone know the difference between an F250 and F350 for any given year of the same year Excursion? I'm guessing the payload of the Excursion is considerably less than the F250, or the F350 (even when the F250 and F350 were only different based on a rear block under the leaf springs). Is that chip getting bigger!!!
How much does an excursion weigh compared to a standard cab standard box (thats what the X is built off right?) F250? The roof, seats, glss, etc etc, is part of teh paylod in my opinion lol.
Old Oct 8, 2008 | 03:36 PM
  #47
Ace!'s Avatar
Ace!
I don't know, how much? Yeah, maybe the gvwr is the same, you tell me. It seems the rear axle rating is the same as the F350, based on another post in this thread, 7000lbs, right? Wouldn't the Excursion be a 1-ton then?
Old Oct 8, 2008 | 03:46 PM
  #48
UrbanXX's Avatar
UrbanXX
Excursion
No that not the way it figured. I actually don't exactly how pay load is figured to be honest with you.
My 03 Excursion Limited is tagged GVW 8100 or 8200 pounds I forget which) GVW meaning Gross Vehicle Weight.
The GVW is why tires are so expensive it takes a Load Range E tire for the Excursion.
The pay-load for a F-250 Crew-Cab is about 2360 pounds verse a little over 1700 pounds for the Excursion. I think the difference is partly because the overall weight of the Excursion would come into play.
Old Oct 8, 2008 | 03:52 PM
  #49
Ace!'s Avatar
Ace!
GVWR should be the same, if they're the same. The GVWR includes the net weight of the vehicle, plus the weight of passengers, fuel, cargo (payload) and any additional accessories. If they are built the same, they should have the same GVWR. If the Excursion is the same as a F250, they should have the same GVWR. By the way, I'm not saying they're not, because I don't know; however, I also know that the F250 and F350 are virtually the same, so if an Excursion is built that same as a F250 (3/4-ton), it's also built virtually the same as an F350 (1-ton). Because of my Napolean complex, I'd refer to an Excursion as a 1-ton as much as I was going to refer to it as a 3/4-ton.
Old Oct 8, 2008 | 04:56 PM
  #50
Monsta's Avatar
Monsta
Sit. Stay.
GVWR for the Excursion is between 8600-9200 depending on configuration.
GVWR for an F-250 is 8800.
GVWR for an F-350SRW is 9700-9900.
It's all in the Specifications tab above. Make sure you compare Excursions to 99-04 Super Dutys even if you have an 05 Excursion.
Old Oct 8, 2008 | 05:02 PM
  #51
housedad's Avatar
housedad
The following information if from the 2004 Sales books for all models. All comparisons are 4X4 4 speed auto and base trim. F series is 137" WB. Calculations are by taking the base weight of a 4X4 5.4 liter and adding the up weight for the V10 or Diesel fron the Payload/Option Worksheet. The V10 adds 103 lbs, and the diesel adds 683 lbs. Excursion weights are listed straight up and need no math.
BASE CURB WEIGHTS
............................V10..........Diesel
F250....................5931..........6511
F350....................5925..........6505
Excursion......,.......7230..........7770
(I do not know why, but the F250 base weight (before engine weight additions) is listed as 6 lbs heavier than the F350. It might be due to different emission requirements. But again, I don't know)
MAX GVWR
F250...................8800...........8800
F350...................9900...........9900
Excursion..........,..8900...........9200
It is interesting to note that the Sales Books have this statement in parenthesis with reference to the GVWR of the Diesel Excursion:
(Computer-selected - not to be advertised)
This is in reference to the Excursion diesel having a higher GVWR. Ford had to do this in order to maintain the same listed payload between the different engine options. Advertising it would be fodder for the environmentalists and might worry customers about power, weight, etc.
Old Oct 8, 2008 | 05:03 PM
  #52
housedad's Avatar
housedad
Ya beat me to it on this one Monsta!!
Old Oct 8, 2008 | 05:25 PM
  #53
1's Avatar
Exactly, and I think once you consider overall how much weight is carried on those wheels I think they will be shockingly similar.
EDIT: I see the thread already went there.
Old Oct 8, 2008 | 05:34 PM
  #54
Ace!'s Avatar
Ace!
Originally Posted by Monsta
.... Make sure you compare Excursions to 99-04 Super Dutys even if you have an 05 Excursion.
Why is that?
Old Oct 8, 2008 | 05:37 PM
  #55
Ace!'s Avatar
Ace!
I guess I'm wondering how or why an Excursion is built on an F250 platform and not an F350. Seems the payload/towing of the F250 and Excursion isn't the same, as it's not the same as the F350. Also if you compare the Excursion to the 99-04 Super Dutys then the Excursion is as similar to an F250 as it is to an F350, since the F250 and F350 are essentially the same during those years, no?
ufvj217
Sep 8, 2015 05:41 PM
hasteranger
Ford Truck Parts for Sale
May 24, 2015 07:01 PM
Psyclopse
Modular V10 (6.8l)
Apr 8, 2015 04:31 AM
rat49f6
Sep 30, 2009 04:06 PM
