Solid axle swap
Old Sep 29, 2008 | 02:20 PM
TexasDiesel97's Avatar
TexasDiesel97
Solid axle swap
Looking to swap in a solid axle into my 97 F-250. Has anyone already dones this? If so how hard is it to do, and what problem might i run into if any? Not a fan in the ttb and kinda partial to a solid axel. Thinking that one from a F-350 should just bolt in its place. thanks for any help.
Old Sep 29, 2008 | 02:26 PM
Neal 97 250's Avatar
Neal 97 250
It is done quite frequently. There quite a few write ups also. They use a Dana 60. usually from an 80's model or F-350.
Old Sep 29, 2008 | 02:37 PM
93f1505.0L's Avatar
93f1505.0L
They do it a lot and I would like to do it too if I can find an axle that isn't a millon bucks. Do a search for SAS and you will find plenty of info. One from a SRW F-350 will bolt right in with addition of a trac bar. brakes vary from year to year so you my not be able to use your same calipers.
Old Sep 29, 2008 | 03:16 PM
TexasDiesel97
Thanks for the help, anyone got an axel for sale thats near me?
Old Sep 29, 2008 | 04:26 PM
78f3504x4's Avatar
78f3504x4
You'll need a DANA 60 from an 85.5-91 F350 (kingpin) or 92-97 F350 (ball joint). Also needed is the F350 track bar, track bar bracket, drag-link, tie-rod, and maybe the F350 driveshaft. I have the swap on my '95 F250 (pics in gallery). These frontends used can be $1500, but can be cheaper, usually $650-$1000 around here in new england.
Steve
Old Sep 29, 2008 | 06:13 PM
Gobstopper909's Avatar
Gobstopper909
youll probly want to save yourself another headache and get the kingpin style... screw them balljoints
Old Sep 29, 2008 | 08:04 PM
TexasDiesel97
What is the difference between the kingpin style and balljoint style?
Old Sep 30, 2008 | 05:17 AM
78f3504x4's Avatar
78f3504x4
Kingpin knuckles are generally considered a little stronger, also easier to do a crossover steering setup. The best write up ever, and will explain everything-
Pirate4x4.Com - Extreme Four Wheel Drive
Steve
Old Sep 30, 2008 | 07:59 AM
TexasDiesel97
thanks steve, didnt know there was so much infomation on the dana 60.
Old Sep 30, 2008 | 09:29 AM
Neal 97 250
Steve
Man! That's alot of info there. I will have to grab a drink and sit in front of the fire to read all that. Thanx for the link.
Old Sep 30, 2008 | 05:07 PM
Gobstopper909
great find 78f3504x4!! reps sent
Old Dec 20, 2012 | 06:53 PM
Alaskancowboy's Avatar
Alaskancowboy
Solid axel swap
I am getting ready to swap to solid axel in
My 85f350 and am wanting more then a 6 inch
Lift by doing this can I use a lift from 99 or 2000 where
I can get 10" lift any help be great
Old Dec 20, 2012 | 08:17 PM
DarkStarMedia's Avatar
DarkStarMedia
I got a set of 09 F350 axles for $300 ish.
I know they are not king pin but I get really big disc brakes...
Richard
Old Dec 21, 2012 | 09:57 AM
Diesel_Brad's Avatar
Diesel_Brad
Way to revive a dead thread.
YES, you can use SD slings but you will need a PMF RSK to move the hanger out to accept the longer front springs. For the rear you you will need to drill out your spring hangers for the larger diameter bolts
OBS RSK SD Spring Hanger Conversion Kit
Old Dec 21, 2012 | 10:11 AM
Alaskancowboy
Well that is good I was hoping so that don't
Sound two hard so that a good deal I am wanting
44 bloggers thanks for input
fordlover801
Oct 21, 2015 02:14 PM
Gear619
May 30, 2014 06:25 AM
77f2504by4
Mar 12, 2014 08:02 PM
bryan5686
Sep 13, 2013 12:06 AM
1994460NC
Feb 2, 2010 10:45 AM
