Solid Front Axle Swap
Old May 29, 2014 | 10:51 AM
Gear619's Avatar
Gear619
I have a 94 F250 351w standard that Im looking to swap my independent front suspension front axle to a solid axle. My truck is bone stock. I was just wondering how big of a job it would be to do? Obviously i need a solid front axle to start off with, but what else would I need to go about doing this swap. Will i need new leaf springs? And what gear ratio should the axle be for a stock transmission? And how exactly do I do this swap, I have a good idea id just like to here how to do it from someone that has done it before ... Any help and advice is much appreciated ... THANKS
Old May 29, 2014 | 10:58 AM
Crewcabber's Avatar
Crewcabber
There are a lot of topics on this here. ACRON1920 has started the most recent one.
Old May 29, 2014 | 12:03 PM
Gear619's Avatar
Gear619
My truck is 4x4 already just independent front suspension
Old May 29, 2014 | 12:24 PM
Crewcabber's Avatar
Crewcabber
Understandable but that post and many bothers will help you with what axles you can use and what all else is entailed
Old May 29, 2014 | 09:50 PM
eakermeld's Avatar
eakermeld
If you are going to do anything more than locking and unlocking the hubs on a D60, you need this info! Good luck!
BillaVista.com-Dana 60 Front Axle Bible Tech Article by BillaVista
Old May 30, 2014 | 06:25 AM
tjc transport's Avatar
tjc transport
i ain't rite
it is a pretty straight forward swap. just get everything associated with the axle. you can use your front springs, but the F-350 springs will give you a smoother ride.
to do the swap you will need the following:
front axle that matches the gear ratio in the truck.
front springs.
front track bar and mount.
ALL steering linkage.
front driveshaft.
rear lift blocks to level the truck.
Mike1
Sep 25, 2017 04:42 PM
kidkyle21
18
Apr 18, 2014 09:48 PM
rampus
Mar 14, 2011 01:01 AM
Twistedtesty
May 24, 2010 09:58 PM
fmco_muddin
Iowa Chapter
Feb 5, 2008 08:46 PM
