4x4 on 91 rangerI just put a
I just put a electric shift motor on .Inow have4 high but no 4 low my light comes on in 4 high but not 4 low I here alot of clicking from computer module behind seat when i put it in four high nothing when when i put it in low what is all this clicking from could module be shot or what else could it be????
Well....that is a weird problem....the way to fix it for good is to put in a stick for the T-case! BUT i kinda figure you want to fix what you got. I really have no clue about how that setup works. I Think (like you said) there is a comp module and a selonoid. What you need to do is get a wire diagram for the system and see if you are getting power to the right wires when you try to shift into 4L. If you are not...might be a faulty module. See what you can dig up.
Dan "Mudinford" MacDonald
'86 Ford F-150 4x4 w/ a spooled mono Dana 44/a spooled 9" running 38" TSL. 300ci, Clifford Intake and Headders, .05" Milled Head with SBC valves, port work
500 CFM Edelbrock, Clif. 290* cam with Rhoads lifters, .040" TRW Pist w/ Moly rings.
Future plans: A draw through Twin(or big single) Turbo setup (to help with the upper end)
Shannon Duggan
09-07-2015 01:09 AM
Force4000
07-09-2014 08:41 AM
jonc123
10-23-2013 03:58 PM
shadowviper12345
03-13-2011 03:43 PM
