Rack and Pinion steering to suit F250
I don't know of anyone that does it. You didn't metion if your f250 is a 2 or 4wd. Keep in mind, 4wd with a solid axle does not lend itself well to rack and pinion steering. the 2wd doesn't work well either. The trick to steering, is to have the steering links follow the same range of motion as the spindles if that makes any sence. So basically rack and pinion is ideal for control arm suspensions with short links such as in most cars and old chevy and dodge 2wd trucks. For our 2wd twin-I beams or solid axle 4wd, the stock steering geometry is tough to improve upon.
You are are way better off just using a stock power steering box. You shouldn't need any type of kit. They are the same for all 2wd's f100, f150, f250, f350. They are dime a dozen here in colorado. You could also order all the parts from your local auto parts store to get power steering put together. I would be shocked to find that your truck didn't come with power steering.
Just checked out your profile, you are in austailia, power steering boxes probably not dime a dozen for you. Maybe we could work out a trade... I will send you a power steering box if you can send a set of those austrailian 2v heads for my 400!!
You might have some luck with the guys at The Pick Up Place but it's not going to be cheap - nothing in Australia is for these things!!!
I'm going to start investigating what's needed to fit a US power steering box to the Australian F-truck as the prices here are just insane.
Cheers,
Toothman
Cheers,
Toothman
Jeepman3
07-06-2014 06:48 PM
f100today
01-05-2014 12:32 PM
hodjibran
12-30-2013 07:33 PM
