Fuel Pump / Cam
Old Sep 23, 2008 | 07:50 PM
tonyde's Avatar
tonyde
Fuel Pump / Cam
Can the fuel pump arm wear down the cam lobe and how can i tell? I replaced the fuel pump, checked the carb, the line coming from the tank to the pump, and that was all fine. But the carb is still not getting gas. I was told that the arm does not ride on the cam and the part that it rides on is replaceable. Any help on this would be great. Thanks
Old Sep 23, 2008 | 07:54 PM
73f100shortbed's Avatar
73f100shortbed
So you have gas from the pump to the carb line? If so pump is working. Does your carb. have the little fuel filter in it? Maybe it is clogged. If gas is coming out of line to carb. then the problem lies with carb. unless I misread your question. Some info on your truck could be helpful.
Old Sep 23, 2008 | 07:57 PM
tonyde's Avatar
tonyde
No sorry I wrote that wrong, I do not have gas from the pump to the carb.
Old Sep 23, 2008 | 10:33 PM
fastfarmer's Avatar
fastfarmer
I have also had to prime fuel pumps in order to get them started. I've not seen an eccentric wear out, probly pretty rare.
Old Sep 23, 2008 | 11:24 PM
mark a.'s Avatar
mark a.
No, it has a 2 piece eccentric & it can't wear down.
Old Sep 24, 2008 | 09:49 AM
beartracks's Avatar
beartracks
On some engines you can miss the eccentric when you install the pump. I would take the line off the carb and use rubber line to run it to a can and see if you get gas while cranking. If no then take the line off the pump and see if it's clear.
Also it may take a while to prime a new pump. Have your tried priming the carb? You can squirt some gas into the bowl vent.
Old Sep 24, 2008 | 11:22 AM
1985 Ford F-150's Avatar
1985 Ford F-150
Thats what I do I just put gas in a spray paint cap and pour it in to start it then the fuel pump will usually take over from there.
Old Sep 24, 2008 | 02:06 PM
Dirt racer's Avatar
Dirt racer
Never seen an eccentric wear out but have seen the bolt come loose that holds it and then it won't work. I always use lots of lock tite on mine when I install it.
Old Sep 24, 2008 | 05:51 PM
chuck101st's Avatar
chuck101st
It's not completely impossible that a new fuel pump isn't bad too. Just a thought.
Old Sep 24, 2008 | 08:32 PM
tonyde's Avatar
tonyde
Thanks, the info on the eccentric really helps. How do I "suction" gas up from the tank to the fuel pump? Can I use air pressure in the gas tank to push fuel to the pump? Yes I have primed the carb and it has started then stalled.
Old Sep 24, 2008 | 11:55 PM
76CamperSpecial's Avatar
76CamperSpecial
Can't help on the priming question, but I did have a related question.
When I bought my truck it had an electric fuel pump on it. The mechanical pump is still there, but not hooked up. I'm wondering why someone would add an electric fuel pump rather than replacing the mechanical pump.
Are there advantages to an electric pump over a mechanical pump. All things being equal, I'd rather install a new mechanical pump since it would be one less set of wires to worry about.
Rick
Old Sep 24, 2008 | 11:58 PM
fmc400's Avatar
fmc400
MSEE
Check the rubber hose that goes from the tank, to the metal fuel line that extends the length of the frame rail. You mentioned the line, but not the hose that connects it to the tank. It's about a foot long, at the back of the truck, coming off the tank. This is overlooked many, many times. If this has a crack in it anywhere, the pump will suck in air and not draw fuel. Sometimes the fuel pump is replaced when this hose is really the problem. This hose takes heavy chemical abuse and should not be ignored.
Also, crank the motor with the distributor cap off to make sure the rotor is turning; that way you'll know you didn't lose the timing chain or anything catastrophic like that. The camshaft of course will not rotate if the timing chain is gone.
I'm thinking that investigating those two things will nail your problem.
For your question - the main advantage to an electric pump is that it can be shut off at anytime, whereas a mechanical pump only stops pumping when the motor cuts out. For example, you can wire an electric pump to an oil pressure cutoff switch. This shuts fuel off to the motor immediately if the oil pressure drops, which prevents extensive bearing damage. In the case of EFI vehicles, the pump can be wired with an inertia shutoff switch, to cut off the flow of fuel in the event of a collision. Lastly, some performance engine builders eliminate the cam eccentric to reduce rotating weight, and instead use an electric pump. However, I've also seen people install an electric pump when the mechanical pump dies, simply out of laziness.
Old Sep 25, 2008 | 08:41 AM
tonyde's Avatar
tonyde
Thanks I will try that advice next. I will let you know how it works out.
Old Sep 25, 2008 | 10:48 AM
73f100shortbed
Originally Posted by UTfball68
Take the fuel line, suck on one end with your mouth, get a mouth full of gas, cover the end of the line with your thumb, put it back on the pump (while making a mess of course), tighten the clamp around the hose to the pump, listen to dad laughing because you're still gagging from the gas you had in your mouth and because of the gas that's all over the place from trying to put the hose on the pump. Take a couple swigs of vodka to get the taste out of your mouth, rub the vodka on your arms to get the burning sensation from the gas off. At least that's what I think you're supposed to do...haha. I'm sure there's a better way, but that's the way I always do it.
Just to add... Try to avoid smoking a cigarette afterward
fancyvern
Apr 22, 2017 02:32 PM
sanders92
1978 - 1996 Big Bronco
Mar 7, 2016 06:01 PM
Dimitri13
Nov 12, 2015 11:43 PM
troutski
Oct 19, 2014 10:24 PM
BrandonV
Feb 27, 2003 04:51 PM
