I have my tw chip on Daily. i can hit 1,200 degrees, does that seem high to anyone? I'm not sure how high it goes on street race. What about when i get my stage 2 injectors in?
Like Ron said.......is this at wide open throttle, or towing....or ? 1200* is nothing if it's only for a short burst. I can peak mine at 1500* rather easily in 140smoke if I'm WOT.......the short bursts won't hurt ya, just don't run it for over 30 seconds or so like that......
6.0L intercooler is good for trucks running stock injectors (like mine), but if you are planning to go bigger, I would suggest getting a Spearco or a DI IC. Those will provide a greater temp drop. The 6.0L intercooler is just too small once you go bigger on the fuel.
Water drops temps, meth adds power. If you are simply trying to cool EGT's down, you would run straight water (or a very small amount of meth mixed in with the water).
