Modular V10 (6.8l)
high idle control with V10
Old Jun 13, 2005 | 03:04 PM
E350superduty's Avatar
E350superduty
I have my high idle control/PTO control box from my old van, and I am wondering if the V10 supports high idle and power take off.
Old Jun 13, 2005 | 04:09 PM
Fredvon4's Avatar
Fredvon4
Because it is a van and must have the 2v V10 I do not know the exact answer.
What I do know:
The gas and diesel motors in 05 got a new brain box that no longer needs the old Auxilery Idle Control (AIC) box, also know as Auxiliary Powertrain Control Module (APCM), because the new PCM can control the electroning throttle via the Stationary Elevated Idle Control (SEIC)
There are more than just idle control features but as I understand it you must have the PTO version of the trany to make the Torque Converter Lock UP signal work with elevated idle. I also know that gas motors do not have the battery charge protect feature that PSD versions do.
Try here to see if you van has these features also:
www.fleet.ford.com/truckbbas/non-html/Q108.pdf
www.fleet.ford.com/truckbbas/index.htm
I use this site a lot and it is hard to find stuff but play around there is a LOT of GREAT information
Old Jun 13, 2005 | 04:26 PM
E350superduty
the van(now sold) was actually a PSD. I actually want to use the high idle in my 05 F-350.
Old Jun 13, 2005 | 06:35 PM
Fredvon4's Avatar
Fredvon4
No the ACPM/AIC box is usless sell it to a 99-04 PSD owner.
Under and behind the main fuse panel are the SEIC wires.
Find the right one and put switched 12VDC to it and at idle the PCM will raise the rpms.
Old Jun 13, 2005 | 09:09 PM
BareBones's Avatar
BareBones
E350SuperDuty - I think I noticed in another thread that you have a manual transmission; in which case the PTO answer is yes, standard. On the other hand they don't recommend extended usage. Unfortunately, I can't seem to find my literature right now.
Old Jun 13, 2005 | 09:16 PM
Fredvon4's Avatar
Fredvon4
I finally got E350 signature to work...gota hover for a long time...E350 I do not like your sig even tho it is cool... I always look there to see what vehicle and options we are working on...
Not sure what the manual tranny brings into the pic as far as PTO is concerned. the PTO sense for the automatic is to LOCK the torqueConverter when PTO engaged and then elevate the idle
Read through that guide I linked to I an sure it is in there.
Old Jun 13, 2005 | 09:22 PM
BareBones's Avatar
BareBones
"Transmission Power Takeoff Provision - This is option code 62R and must be ordered to get a PTO gear and port with the TorqShift 5-speed automatic transmission. The 6-speed manual overdrive transmission has a PTO gear and port standard."
This is for 2005 F-250/F-350 Super Duty Pickups.
dstrahm
Aerostar
17
May 13, 2025 06:04 AM
90pioneer
6.7L Power Stroke Diesel
Nov 2, 2015 11:48 AM
clawsd
Modular V10 (6.8l)
Mar 20, 2015 04:00 PM
Pat Taugher
Dec 28, 2014 10:59 PM
otrawj
Feb 11, 2011 02:14 PM
