Intercooler Hot pipe paint
Old Sep 18, 2008 | 12:28 PM
DieselBeast01's Avatar
DieselBeast01
When you guys painted your intercooler pipes, what kind of paint did you use?
Old Sep 18, 2008 | 12:31 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
any kind of engine primer and enamel... i think i used 500 degree but not sure. But it hasnt flaked yet so im happy
Edit: Used Ford red of course too
Old Sep 18, 2008 | 12:33 PM
Adam0331's Avatar
Adam0331
I used the duplicolor engine enamel
Old Sep 18, 2008 | 12:35 PM
DieselBeast01
Thanks guys I really need to repaint mine because it has begun to flake off.
Old Sep 18, 2008 | 01:06 PM
Ponyboychris's Avatar
Ponyboychris
What did you use before?
Old Sep 18, 2008 | 01:50 PM
sideshow's Avatar
sideshow
i used brake caliper paint. i'll actually probably repaint and clear them, so they stay shiny, like i did on my dad's 6.0.
Old Sep 18, 2008 | 02:59 PM
redfire42's Avatar
redfire42
Do you need to primer first?
Old Sep 18, 2008 | 04:16 PM
Automator's Avatar
Automator
Primered mine first, usually a good idea anyway.
Old Sep 18, 2008 | 06:37 PM
Adam0331's Avatar
Adam0331
It's probably a good idea but I didn't. I roughed it up with steel wool.
Old Sep 18, 2008 | 06:41 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
You can use high temp powdercoat too.
Old Sep 18, 2008 | 09:56 PM
parkland's Avatar
parkland
You shouldnt need high temp paint for the IC pipes should you?
I left mine "aluminumized" in color to prevent further mainteneance.
Old Sep 19, 2008 | 03:07 PM
redfire42's Avatar
redfire42
Maybe I will just polish mine to see if I like it before paint.
Old Sep 19, 2008 | 07:07 PM
sideshow's Avatar
sideshow
i don't think high temp paint is necessary, but i used the brake caliper paint cause it get's pretty hard and fairly chip resistant (even though i managed to chip mine when wrangling the turbo in and out). i also feel safer spraying some degreaser or brake kleen when i clean up the engine bay.
Old Sep 19, 2008 | 07:09 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I second the duplicolor worked great on mine.
Old Sep 19, 2008 | 07:24 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
you dont want to do that either! i tried it and it looked great until it started rusting. i then realized i polished all the protective coating off. you guys should just get them powdercoated. check these out....
