Programmers improve auto trans functions?
Old Sep 18, 2008 | 09:29 PM
DG65's Avatar
DG65
Do the programmers from DP-Tuners and TW improve, change or customise any tranny shift functions? I've been told they help as far as keeping the tranny in OD - or is that simply because of the power increase requiring less throttle?
Thanks everyone.
Old Sep 18, 2008 | 09:37 PM
c00nhunterjoe's Avatar
c00nhunterjoe
to a point they can. they can change strategy and pressure but to get a good shift and reliability you need to replace hard components
Old Sep 18, 2008 | 09:43 PM
DG65's Avatar
DG65
When hard parts are required I'll be stepping up to something better. I thought maybe I could improve a bit on what I have until that dredded day.
Thanks, coon.
Old Sep 18, 2008 | 09:46 PM
c00nhunterjoe
a simple shift kit goes a long way. and on top of that, custom trans tunes such as "the cure" you will have a sweet shifting trans as long as you dont overpower it with ponies and torque
Old Sep 18, 2008 | 09:50 PM
c00nhunterjoe
all i run is a shift kit in mine with over 150k on it, i would estimate the truck to put out no more than 300 horses and 550 ft lbs of torque. never dynoed it but it runs ok. i tow frequently and run it hard, trans shifts great, never slips.
Old Sep 19, 2008 | 07:09 PM
DG65's Avatar
DG65
The "cure"?
Old Sep 19, 2008 | 07:19 PM
tjbeggs's Avatar
tjbeggs
Originally Posted by DG65
The "cure"?
Little reading for you
The Ford Transmission Cure for shift flair problems
https://www.ford-trucks.com/forums/7...ift-flair.html
To answer you orginal question, yes chips and programmers can change line pressure and shift points. Custom chips like TW and DP do it much better.
Old Sep 19, 2008 | 07:50 PM
DG65's Avatar
DG65
Hmmmm.....
With all the tranny talk around here I've never heard a mention of The Cure.
Old Sep 20, 2008 | 04:49 PM
c00nhunterjoe
tim mentioned it and posted a link, however "the cure" is not a shift kit. while it is a very good design and i really like what it can do, it does absolutly nothing for shift firmness or patterns. "the cure" and a shift kit together would be really neat.
Old Sep 20, 2008 | 04:53 PM
tjbeggs's Avatar
tjbeggs
Very True!
Old Sep 20, 2008 | 06:04 PM
DG65's Avatar
DG65
This will be something to consider.
Thanks.
Aussie7.3
15
Feb 13, 2016 04:45 AM
excoelis
2009 - 2014 F150
Jun 19, 2013 07:39 PM
boulderbronco
6.4L Power Stroke Diesel
Feb 22, 2008 04:17 PM
dkoenig
Jan 8, 2008 03:34 PM
shoccwave
1983 - 2012 Ranger & B-Series
17
Dec 6, 2006 03:58 PM
