Early 99 PSD "No Start"
If I knew just what it is supposed to do and how it works, I'd do it in a heart beat.
Lets see,,, it obviously involves a high voltage supply to the coil and closing the circuit then opening it very rapidly, thus the "Buzz".
I don't know though if it uses AC or DC current??? Any input here?
It shouldn't be that difficult to setup even a basic "Buzzer" that only works one injector at a time...
Has anyone done this kind of thing before?
Catchup
Still she no start...
Catchup
A bad injector solenoid can cause the IDM to shut down the entire bank of injectors, but loosing one on each side at the same time is pretty rare. You would also see a difference in the OHM readings for the bad injector (from the valve cover plug) than the rest of the injectors.
Have you tried measuring voltage at Pin E (center pin) to the battery ground with KOEO?
First step:
Disconnect IDM connector and test resistance across common (High side) and each low side circuit for each injector and bank,,,
3.2 OHMS consistently across all circuits.
Second step: Beings I already had the valve covers off I isolated ALL of the injectors (removed the injector harness connectors from the injectors) and tested the coils individually with a section of the old UVCH that I cut up to make a test connector...
3.1 OHMS directly across the coil connector X 8.
Third step: I removed one of the coils from the engine, put it on the bench and read 3.1 OHMS. (I didn't remove all the coils, just the one)
I've read that from 3 to 5 OHMS is showing a good coil...
Is this correct for my early 1999 and beings how mine are on the very low side of that range, does it mean that I have 8 questionable injector coils???
More to come...
Catchup
yup still beating it...
That kind of brings us back to the high readings you had with the OHM meter at the IDM connector. Did you check for continuity in the wiring between the IDM & Valve covers? It would be helpful to have someone wiggle the harness while checking continuity to make sure it's not an intermittent fault in the wiring. Have you checked voltage from the VC connector to the battery ground? Those are the last free tests I can think of before you start having to spend $$$.
Maybe someone else has better ideas.
>>>Yes the coil that sits on top of the injector. I just wanted to make sure there was no interference so I removed one and put it on the bench.
>>>These readings were actually on the 2 million ohm scale.
>>>I got these by testing between common and ground to Battery negative
and they run anywhere between 500,000 and 1,000,000 ohms. (I probably shouldn't have looked at that huh...)
>>>Yes and have practically unwrapped the entire harness looking for anything...
>>>Grabbed, shook, twisted pulled wriggled and even shouted at it...
>>>No shorts
I hope so...
If I could just make sure it's the IDM I'd get one but,,,
I hate to be labeled a "Parts changer"...
PS: Thanks for hanging in there with me...
Catchup
Maybe there's someone close to you that will stick the questionable IDM in there truck to see if that's the problem. I'm still a little concerned with the P0605 code since there aren't a lot of items to check on the diagnostic tree before it gets to the "Replace PCM" part.
>>> I wanted to be nice...
>>> If it wasn't such a pain to get to it I probably could...
>>> It seems that I was handed a 1999 that's running for some good reason huh...
I might just have to do that,,, hmmm, don't tell Wayne or Brian though...I'm still a little concerned with the P0605 code since there aren't a lot of items to check on the diagnostic tree before it gets to the "Replace PCM" part.
>>>I have found that code to jump up when I disconnect the battery for one reason or another too...
Can you believe we got a truck given to us for a couple days that just happens to be a 1999 F-350 7.3L PSD, thank you Lord
Catchup
PS: I will post the results here...
If the P0605 is just from disconnecting the batteries, then the IDM sounds like the place to start now that you just happen to have another one handy.
I'll be looking forward to hearing what you find.
I new that the PCM was sending a signal to the IDM for the
Fuel Pulse Width. (I got a pulse reading on the scan tool)
I had isolated all the injectors from each other and OHMed them,
they all recorded 3.2 OHM's... This is within acceptable parameters
so the injector coils are all good.
I disconnected the IDM connector and the big square connector
that sets on top of the left valve cover and diligently searched for
a short or broken wire, both visually and electrically (continuity and ohms).
I satisfied myself there were no problems in the harness.
As stated I had already replaced the valve cover gaskets, UVC
wiring harness, glow plugs and the CMP sensor.
I determined that the only thing left between the PCM and the injectors
was the IDM. I ordered one from Auto Computer Exchange, (an ebay store)
for 159.95 + shipping. The total charge was just under $200.00. The part got here very quickly and I ran right out and stuck it in.
Bottom line,,, it started!
After all this, I really want to get some schematics and parts lists
for PCM's and IDM's and GEM's and start a little shop to rebuild them...
Anyone got any ideas along this line?
They don't really appear to be that complicated...
Anyway's thanks for all your help
Catchup
I'll let you know if I can find anything on the IDM info. A couple of people come to mind that I'll ask.
