i lifted my straight 6 flathead from a water pump bolt and a chain wrapped around the back of the transmision yes the cab was off the truck so that gave us the clearance
You can build a plate if you want to do a lot of work and feel like you've created some piece of art, but otherwise just get a couple long head bolts and lift it with chains and hooks.
Here's some pictures:
But if you don't like to do it that way, here is a great link that went around earlier.
I know the numbers and experience say it "can" be done, but three 1/4" bolts doesn't work for me, to support maybe 700 lbs.?? If the hoist jerks when lowering, the load multiplies several times. Julie's rig looks good to me, or using a lifting plate that replaces the intake manifold. You have to weigh the risks...
