Question on torqshift relearn strategy
Old Sep 14, 2008 | 04:53 PM
2kcrewcab's Avatar
2kcrewcab
I am 99.9% sure this is the problem with my tranny. Truck started shifting erratically right after giving my brother in law a jump.
Got a question about the process. Do you do the light, medium, heavy acceleration in normal mode, then the n-r, n-d, d-r, r-d then repeat the same process in tow/haul. Or do you do the light, medium, heavy in both normal and tow, and then the n-r etc etc etc just once.
Anybody who has had to do this before have any tips? Seems pretty straight forward, just wanted to clarify..
Old Sep 14, 2008 | 06:02 PM
liv's Avatar
liv
I'm not quite sure on what your asking. Most people just unplug both the batteries.
Old Sep 14, 2008 | 09:44 PM
powerstroke765's Avatar
powerstroke765
Bully Dog has a relearn process for the torqe shift on their web site, but it is for after programming the ecu. Check it out it may help you.
Old Sep 15, 2008 | 07:39 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Just drive it. It will relearn. The procedures are to make it learn faster, but you don't have to do it.
You can do the d-r, etc, in tow/haul or not, it doesn't matter.
Old Sep 15, 2008 | 09:41 AM
2kcrewcab's Avatar
2kcrewcab
I thought just driving it would relearn but it isn't. It's been about 2 weeks now and it sucks! the shifting is very erratic. Sometimes I could start the truck up and it runs great until the tranny gets warm (about 150) and sometimes it starts acting up as soon as I start the truck. The erratic shifting, slipping, hard shifts, etc. Sure sounds like it need to relearn.
Old Sep 15, 2008 | 11:13 AM
KRDiesel's Avatar
KRDiesel
Did you disconect the batteries and give it 20 minutes to clear? Also how old is the fluid? it could be time for a change.
You also may need to check for codes, I think Auto Zone can pull trannie codes, BTW the CEL will not set for most trannie codes.
Old Sep 15, 2008 | 12:34 PM
Mark Kovalsky
Autozone can't read Ford trans codes. The Tow/haul light will flash for all trans codes, but the CEL will only light for certain ones.
You do need to reset the PCM to get the learning to work right. Sometimes the learning can learn itself into a hole that it can't find the way out of. Disconnecting both batteries will clear the memory and allow it to start over.
Old Sep 15, 2008 | 12:41 PM
KRDiesel's Avatar
KRDiesel
I stand corrected. I did not know about the tow/haul flashing.
the Auto Zone in Los Alamos had a new actron 9190 that can read most of the extended and enhanced codes. BUT, I have not tested the tranny codes on a ford, just a GM.
BTW, Mark, Do you recomend a larger cooler, I do not tow allot, but I live in the Rockies, and go off roal allot.
Old Sep 15, 2008 | 04:58 PM
2kcrewcab's Avatar
2kcrewcab
Thanks alot guys! I have not disconnected the batteries yet. I knew about the tow/haul flashing for tranny codes because my '00 did that when the pcm crapped out. I live in a pretty hilly area (NW PA) so once the tranny gets to the slipping point, it is rough driving. keeping the tranny from slipping up a larger hill, I will go from 60mph to maybe 25 by the time i get to the top. I will reset the batteries
Old Sep 15, 2008 | 05:10 PM
UGA33's Avatar
UGA33
After switching back to stock from a tune, my tranny did this exact same thing. Waited for it to relearn, never did. Did the battery disconnect and went through the relearn process in the tech folder and all is well!
Kep4's Avatar
Kep4
Jäger
Thanks for the info Mark! I sent you some positive rep points for your efforts, as always it's very much appreciated.
ShaneNP123
59
Sep 12, 2017 08:08 AM
Twofish
1997 - 2003 F150
Jun 5, 2017 07:44 AM
Jeff53
Mar 19, 2017 01:54 PM
scelogistics
Sep 12, 2016 05:09 PM
Swantastik
Escape & Escape Hybrid
13
Nov 24, 2014 12:10 PM
